73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: 78 Chevyrado on September 01, 2011, 06:34:43 pm
My hinge spring broke yesterday. the thig actually twisted in half down by the bottom where it curves. so... i need a new one, I have some around here somewhere, i have a toold for installing the spring, but i dont see how it will work with the door and or fender on the truck.
I cant find the posts about changing that spring, I really dont wanna have to pull the door loose or anything cuz i didnt make a disconnect for the power and speaker wires that run through the loom from the cab to the door and cannot disconnect them. ::) and i need to keep that particular hinge becasue one its really new, and two its painted body color and i dont wanna have to go have a hinge color matched so it looks right.
Any help and pics would be greatly appreciated.
I would honestly replace the hinge. They have new pins, bushings and spring. The door check won't pop or creak. You can support your door carefully with bubble wrap, a foam pad and a jack.
It can be done with the door and fender in place. Its a big pain in the rear, but I have done it, just need to fish it in there, pry it over, and slide it into place.
I got it in there. took about 4 minutes to figure out how to do it, and about 30 seconds to pop it into place. cool beans. I cheated a bit though, I had an extra hinge i could practice on on the vise before i started. ;D
Cheaters never win
Cheaters never win
I believe you now... right after I got that fixed the ignition system took a crap... >:( Its ok though, a new distributor and plug wires and its running so smoothly i cant tell if its running at a redlight without looking at the tach. i didnt cheat this time so maybe im good now. ;)
It evens out! ha
haha thats crazy man. glad all is well for time being.
I know this is an old thread, but I was wondering if you could provide info on the installation tool you used. Thanks.
