73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: pedigo78 on September 02, 2011, 07:29:02 am
I have an 85 k20. so i was wondering did they make any np205 that are full time full wheel drive. I was doing some work on my transfer and put it all the way forward which should be 4lo everything was good, then i pulled back it was nuetral, then pulled back again and two wheel drive. well thats all the pulling i can do, so i put it back forward to see if i was just missing a gear but it alwys went from lo to nuetral. i dont know anyone have an idea.
The 205 did not come full time. Has your transfer case ever been rebuilt ? Sounds to me like it might need it if you can not shift into all the gears.
clean and lube shift linkage before rebuild...
Yeah, i will play with it again. maybe i was just missing it.
Heres the shift pattern so if your getting it into 4 hi your going past 2 hi
http://www.chuckschevytruckpages.com/images/NP205knob.jpg
like beast said mud can get up into the linkage and not shift right. also someone on here had a problem where the shifter handle was hitting the floor causing it not to shift right
Yeah, I went and played with it some more and I think it is fine now. Thanks for yalls help
