73-87 Chevy _ GMC Trucks => Performance => Topic started by: BULLDOG on September 04, 2011, 02:53:05 pm
Where doing a head and cam swap on a 350 for the 83 K20.
Where going to use some ZZ4 heads with 58 cc chambers the piston to deck clearance is .024 the pistons have a 12 cc dish and where esing a .028 head gasket and the Voodoo 60101 cam
http://www.summitracing.com/parts/LUN-60101
Do you all think I will get into detonation with this combo?
You'll have to run the highest octane rating for your fuel... Run a cooler t-stat and play with the timing.
Also run a colder spark plug.
You guys recommend me a cam that will work good with my combo
go to compcams.com and they have a sheet you to fill out, give the most info you have on the truck, weight, engine, RPM's (your goal) gear ratio, cc, your tire size, use of the vehicle, compresion, etc.. and they will get back to you with a part #
Ho about we build it and put it in your truck too. Would you like us to break in the cam as well? ;D
that would be nice while you all are dropping in the engine and breaking it in the truck needs wheel bearings and the transfer case is leaking
Done
Please pay at the next window.
the leak aint nothing mud has a had time sticking to oil. run her till the wheels fall off ;D
