73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: p7387 on September 13, 2011, 02:33:02 am
Title: power window regulators (year differences)
Post by: p7387 on September 13, 2011, 02:33:02 am
looking to switch the passenger side manual regulator to power. i have a 87 2wd so what year donor truck will have the regulator i need.
i ask this because i see   splits the years for power regulators from 77-81 and 82-87
thanks
Title: Re: power window regulators (year differences)
Post by: slmdchvy05 on September 13, 2011, 03:01:40 pm
Im not sure what all years are the same, but I have a 84 and swapped all the internal out from a 91 suburban and they all work no problems the plugs are the same for the regulator but when you go down the wiring harness the plugs are different. If you get a donor and the plugs are different all you have to do is pull the pins that the wires are connected to out of one plug housing and put them in the other plug housing.
Post by: Captkaos on September 22, 2011, 11:19:55 am
They say the 77-81 motors are better, either should swap though...
