73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: cruisinc10 on September 14, 2011, 05:18:12 pm
Title: cab leak
Post by: cruisinc10 on September 14, 2011, 05:18:12 pm
Hey guys hopefully you guys can help me out. I have a 84 k10 silverado, all original, ac truck. I bought the pickup back in july and I drive it every day. It hasnt rain much at all since i have bought the truck but today it just poured. This morning it was drizzling,I got in the truck and the drivers floor board was wet, then later at work I went out on break, it was pouring and the driver side floorboard was soaked,there was a slow drip under the dash right above the brake pedal. Any ideas guy? no cab lights or visor
Title: Re: cab leak
Post by: zieg85 on September 14, 2011, 06:10:40 pm
Probably your cowl has a problem with rust.  Pop the wiper arms off, remove the cowl, and plastic and you will probably find all kinds of stuff down there.  Because mine aren't for show I clean them the best I can, remove the rust and I have had great luck using paint-able silicone caulk to plug the problem.  Then when all has dried I use 100% solids 2 K epoxy and seal it up.  Never had it leak again on me.  There are other fixes that I am sure will be commented on but this is what has worked for me.
Title: Re: cab leak
Post by: Radioflyer on September 14, 2011, 07:47:43 pm
I never did anything about this problem you just described and my 1st trucks drivers side floor boards and rocker panel are completely rusted out. I never sealed it up and ten years later I have a parts truck :-\
God Bless ya,
Jay
Title: Re: cab leak
Post by: HAULIN IT on September 14, 2011, 07:57:06 pm
Besides the cowl that Zieg noted...Check the bottom of the windshield & the fresh air vents, I've seen both of these cause problems also. Good Luck, Lorne
Title: Re: cab leak
Post by: thirsty on September 15, 2011, 07:05:13 am
God Bless ya,
Jay
X2 on this.
I had a similar leak in my 86 cab. I kept blaming it on a visor bolt where it looked like they caught the visor on a branch 4 wheeling or something. I kept trying to seal it up without removing the visor with no luck. When I tore my truck down I found the problem was not that visor bolt but another one that looked fine. That damaged my truck worse than just the floor. If I had looked harder when I first got the truck I might not be prepping my new cab for paint now. Keep digging until you find the leak.
Title: Re: cab leak
Post by: cruisinc10 on September 15, 2011, 10:01:05 am
I pulled the cowl off when I first got it to clean the junk out but ill pull it off again and look for holes.
Title: Re: cab leak
Post by: cruisinc10 on September 15, 2011, 10:44:10 am
On the fresh air vents does it pull the air through the cowl? Thanks again guys
Title: Re: cab leak
Post by: mdws1987 on September 15, 2011, 11:13:15 am
Don't forget the door seals. My 87 R10 driver side door was out of adjustment. It had dropped down. Got the door fixed and I replaced the seal....
Title: Re: cab leak
Post by: cruisinc10 on September 15, 2011, 11:20:48 am
Its not the door seal, it driping from under the dash
Title: Re: cab leak
Post by: 69byrd on September 15, 2011, 01:52:48 pm
x2. My granddads old truck rusted under the windshield rubber and it leaked everytime it rained hard.
Title: Re: cab leak
Post by: cruisinc10 on September 16, 2011, 11:20:43 am
Thanks ill check that out as well
