73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: AJII on September 17, 2011, 09:52:55 pm
Title: Help With Wiring Identification!
Post by: AJII on September 17, 2011, 09:52:55 pm
Hey guys,
My dad and I finally got our 85 K10 carb'd 5.3 swap running!  ;D
Couple of questions...
1) The blower motor doesnt work at all and all fuses are good/relays connected. The temperature control lever is stuck as well..is this just the sign of a bad control box?
2)Trying to clean up some of the underhood wiring mess, and I cant figure out what this bundle of wires connects to? I've  searched but cant find the connector/wire color anywhere.
(http://i298.photobucket.com/albums/mm241/mississippi305/b32f8a5d-1.jpg)
(http://i298.photobucket.com/albums/mm241/mississippi305/ecdcd551.jpg)
(http://i298.photobucket.com/albums/mm241/mississippi305/1b975a59.jpg)
Title: Re: Help With Wiring Identification!
Post by: apchas on September 25, 2011, 01:44:58 pm
The last 2 pic are for cruse control mod.
Post by: 1980c10 on September 25, 2011, 05:33:00 pm
1). I think it is more likely that you have two seperate problems.
you may just have a bad motor-to test it; remove it and connect it directly to battery power.
as far as the lever not moving; inside of the heater box(where your fan is mounted) there is a flapper door. that could be jammed up not allowing the cable to move.
