73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Mike Phillips on September 24, 2011, 11:44:53 am
Title: Help - Need help identifying a part number for this compression washer?
Post by: Mike Phillips on September 24, 2011, 11:44:53 am
I was able to get the right bearing and seal at NAPA for my Dana 60 frontend but they couldn't find a part number for the compression washer.
Here's what I'm working on, front axles for a Dana 60
(http://www.showcargarage.com/gallery/files/1/CompressionWasher02.jpg)
Here's the bearing and seal kit I bought at NAPA
(http://www.showcargarage.com/gallery/files/1/CompressionWasher03.jpg)
Here's the part I need a part number for...
(http://www.showcargarage.com/gallery/files/1/CompressionWasher01.jpg)
Title: Re: Help - Need help identifying a part number for this compression washer?
Post by: thirsty on September 24, 2011, 12:05:22 pm
That looks like a flat washer/spacer. You can't reuse it Mike?
Post by: Mike Phillips on September 24, 2011, 12:30:52 pm
I could but I've been replacing everything with new parts just to do the job right the first time.
I shows signs of wear I can take a better picture later...
Trying to get both the frontend and rearend all re-assembled this weekend.
Post by: bake74 on September 24, 2011, 09:09:24 pm
     Mike, I just went through this, Dan the man at my local Oreilly's hooked me up.  It is called a pre-load washer for the spindle bearing kit, I had to contact my local gm parts guy at a dealership and have him look ( they really don't like to have to do any work ) in the computer for a diagram of the axle breakdown, he could order for me, so I turned it over the the friend who's truck I was working on and he got it.
    Hope this helps, but that is the only place I could find it.
Post by: Mike Phillips on September 25, 2011, 06:47:45 am
Thanks for chiming in... around me I have Autozone, Advanced, Bennett and NAPA parts stores so I print out this thread and then swing by and see if any of them can help out.
Thanks!
Mike
Post by: Mike Phillips on September 25, 2011, 08:56:37 am
***Success**
Kevin at my local NAPA knew of a Dana website where he could look up the part number and then order it from Spicer.
 ;D
Post by: thirsty on September 25, 2011, 09:23:09 am
***Success**
 ;D
Good deal!
Sounds like it would be a good addition to the parts numbers thread or section if it happens.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=21676.0 (http://forum.73-87chevytrucks.com/smforum/index.php?topic=21676.0)
Post by: Mike Phillips on September 25, 2011, 02:40:21 pm
Quote from: thirsty
Good deal!
I take a picture of the packaging, part number and part and added to the parts number thread.
