73-87 Chevy _ GMC Trucks => Interior & Equipment => Steering Columns => Topic started by: 84chvy on October 04, 2011, 10:56:21 pm
Title: ignition trouble
Post by: 84chvy on October 04, 2011, 10:56:21 pm
ok guys. so heres the jist. someone tried to steal my truck before i gotit and yanked out the ignition in the steering column. so i have been starting it with a pair of needle noses. how hard will it be to replace this? will i have to strip my whole steering column? need help! :-\
Title: Re: ignition trouble
Post by: beastie_3 on October 05, 2011, 12:22:01 am
Take a look at the steering column rebuild in the tech section to start off with. We also have wiring diagrams in the same section. You should be able to replace everything without much trouble. Do you have a local pick and pull type junk yard?
Post by: Irish_Alley on October 05, 2011, 12:39:23 am
wait they "tried" to steel your tuck sound like they did, and drove off with it. i mean if you can start it with needle noses they should of been able to do the same
Post by: Captkaos on October 12, 2011, 04:38:10 pm
Check the tech section, it gives you step by step on how to get down to the cylinder.
Post by: VileZambonie on October 12, 2011, 05:06:28 pm
If they broke the column jacket just get a used column. If it's just the ignition cylinder then just replace the unit.
