73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: boyer61 on November 06, 2011, 10:52:51 pm
Title: Extended tip or no?
Post by: boyer61 on November 06, 2011, 10:52:51 pm
It's calling for R44ts for light duty, r44t for heavy duty.
On the TS, the tip is more extended, the T it's must more recessed into the plug.
Which one should i use?
Motor is a 77 305 bored out .30 over, slightly mild cam, and headers.
Title: Re: Extended tip or no?
Post by: 1980c10 on November 06, 2011, 11:20:48 pm
I will always go with what is recommended with the heads I am using. The safer bet would be the r44t as it would give you more clearance on your pistons you don't want to get too close and create a "hot spot". If, however, you have been using the r44ts I would stick with them. I am not speaking from experience on this, just what crosses my mind.
Post by: boyer61 on November 06, 2011, 11:27:10 pm
Im currently using r43ts, one stage colder than the 44's.
The heavy duty and light duty threw me off lol
