73-87 Chevy _ GMC Trucks => Fuel Systems and Drivability => Topic started by: jm9744 on November 16, 2011, 09:13:10 am
Title: Need to know electric choke wire color for 1986 305
Post by: jm9744 on November 16, 2011, 09:13:10 am
I am putting a stock quadrajet back on a 86 C10 with 305. The truck had an aftermarket carb with the chock wiring modified. I have one wire with a plug on it but it doesn't fit very well (may be broken) and another wire that was connected to the aftermarket choke (hot). I bought a new pigtail for the factory choke and just want to wire it to the correct color in the harness. So if you have a 1986 with a 305, could you please look at the color of the wire that plugs into your choke and post it on here. Thanks
Title: Re: Need to know electric choke wire color for 1986 305
Post by: thirsty on November 16, 2011, 11:00:53 am
Here is a link to the wiring diagrams on this site. You can make the images bigger so that you can read everything once you go to the diagram that you need.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,11766.0.html (http://forum.73-87chevytrucks.com/smforum/index.php/topic,11766.0.html)
(http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/81-87_V8_engine.jpg)
Post by: jm9744 on November 17, 2011, 03:45:23 pm
Thank you!
