73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: sleepchamber on December 05, 2011, 04:35:00 pm
Anyone ever had the lockup converter slip in and out? Engages at 45mph and seems to stay engaged as long as I stay at 45mph....anything over and back down to 45mph the converter slips in and out of engagement constantly. This is an '85 C10, 305ci, non-computer controlled carb and distributor.
Fluid level and condition is good? Low vacuum switch is connected and detent cable properly adjusted? TCC Brake switch is OK?
Fluid is clean and full...the vacuum switch is connected...detent is not connected. What is the TCC brake switch?
Check the switch adjustment (common cause of the symptom you're describing). The switch is depressed by a metal bracket bolted to the brake pedal arm, behind the dash. If not adjusted correctly, minor movement of the brake pedal while driving will cause frustrating converter disengagement.
Will check this when the weekend comes....thanks for the suggestions.
It was....a dry-rotted vacuum line to the switch behind the brake booster. Went ahead and replaced all of the vacuum lines. Thanks dudes.
