		73-87 Chevy _ GMC Trucks => Electrical => Topic started by: Firebreather on December 12, 2011, 03:32:31 pm
				Help! No dash lights, I replaced light switch, checked fuse, replaced inst cluster bulbs, and still no glow...................
				     Did you check your printed circuit board to see if the connection for the dash lights got cut or broke somehow ?  Check to see if you have power at the dash lights and work your way back to fuse block.
				Did they work before, what changed?
				Don't forget the ground.
				Thanks for the help, I will try tomorrow. They did not work before, the kid before me did a GREAT job of taking things apart and cutting wires.
 I don't think he missed a screw or a wire........... ???
				Did you adjust the dimmer?
				Yes, I did try the dimmer, I tried the obvious first. :)
