73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: bbohannon1 on December 12, 2011, 08:10:17 pm
Title: Removing factory oil cooler
Post by: bbohannon1 on December 12, 2011, 08:10:17 pm
'85 C20 5.7L. Oil cooler supply line is leaking. I want to remove the oil cooler as other have done. Is this the right/best part for the job? http://www.summitracing.com/parts/CVS-OFA65/  Thanks in advance!
Title: Re: Removing factor oil cooler
Post by: Captkaos on December 12, 2011, 08:19:55 pm
You talking about the piece that is bolted to the oil filter pad on the block?
Post by: bbohannon1 on December 12, 2011, 08:29:19 pm
Yeah. I want to loose the oil filter mount that has the hoses to & from the oil cooler and replace it with one without the hose connections.
Post by: Captkaos on December 12, 2011, 08:51:18 pm
Just unbolt it and put the bypass valve in it, that one you listed doesn't have a bypass....
Post by: bbohannon1 on December 12, 2011, 09:26:30 pm
I obviously don't understand what's going on.  :-[ What's a bypass valve?
Title: Re: Removing factory oil cooler
Post by: Captkaos on December 12, 2011, 09:55:02 pm
I was just pointing out that most factory Chevrolet filter bosses have a bypass built in, that one doesn't.
Post by: firefightin1 on December 13, 2011, 08:54:51 am
if you keep you oil changed every 3000 miles or so you dont have to have a bypass valve, all it does is keeps the oil filter from clogging up and starving the engine of oil, however for street use of an engine i highly recommend using a bypass style, i only use the non bypass on race engines.  hope this helps a little
Post by: VileZambonie on December 13, 2011, 10:24:26 am
http://www.summitracing.com/parts/SES-3-60-08-900/
This is what you need and eliminating the oil cooler is a good idea.
Post by: bbohannon1 on December 16, 2011, 09:33:35 pm
What about gaskets I might need?
Post by: Jason S on December 17, 2011, 06:05:46 pm
I don't want to hijack the thread but...
Why would eliminating the oil cooler be a good idea?  If you tow anything, especially on a hot day in summer I'd think the oil cooler would be a nice thing to have.
Post by: VileZambonie on December 17, 2011, 06:35:38 pm
The only gasket is the oil filter. The bypass adapter bolts directly to the block just make sure it's nice n clean. There will be gaskets with the cooler set up.
Quote
Because they leak and if it does by the time you realize it, too late. You know how many engines I replaced for this same reason? If it was a crate engine replacement you needed to bypass the oil cooler or the warranty for the engine was void. If you use good oil you've got nothing to worry about.
Post by: trink2030 on April 21, 2012, 06:26:15 pm
Hello!
I ordered this part for my 1985 454 c3500 from summit.  I didn't realize this thread was for the 350 when originally reading.  When I got it, it didn't look like it would bolt up, so I called Summit and they said that it 'should' work.  Does anyone have any comment for the same part on the 454?
On a side note, the reason I want those lines gone is because they are leaking.  I bought the dye at the below link and used a 365nm UV light and it is clear as day where my motor has leaks at. At night it shines like it's radioactive under the UV.  Awesome stuff.
http://www.amazon.com/Tracer-Products-TP34000601-Fluorescent-Detection/dp/B000JFHNTM/ref=sr_1_1?ie=UTF8&qid=1335050649&sr=8-1
Post by: trink2030 on April 21, 2012, 07:29:58 pm
Also, is the part at the below link what I should be removing when I do bypass the cooler?
http://www.rockauto.com/catalog/raframecatalog.php?catalog=342&partnum=25013759&a=FR342-25013759-794526
Thanks again
Post by: VileZambonie on April 22, 2012, 08:22:32 am
Not sure what you are linking to but when you remove the cooler adapter and lines just make sure that the block is clean. Old gasket material and crud builds up in there and if you are going to use the standard bypass valve then it needs to be really clean. No gasket is used except for the oil filter o-ring.
Post by: bd on April 22, 2012, 06:14:04 pm
I ordered this part for my 1985 454 c3500 from Summit.  ...When I got it, it didn't look like it would bolt up, so I called Summit and they said that it 'should' work.  Does anyone have any comment for the same part on the 454?
This is what you need....
Vile linked the bypass valve/oil filter adaptor for your Mark IV big block (and all other production Chev V8s from ~1968 through 1987+).  The actual bypass valve is the little pale brown colored fiber disc.
...when you remove the cooler adapter and lines just make sure that the block is clean.  Old gasket material and crud builds up in there and if you are going to use the standard bypass valve then it needs to be really clean.  No gasket is used except for the oil filter o-ring.
As stated, remove the old filter base with the oil cooler hose ports, clean up the block (be careful of razor sharp edges), and then install the new filter base that you purchased - NO gasket or sealer.
Tighten the two bypass valve mounting bolts to 18-20 lbs-ft.  Install a new filter, add oil as needed, check for leaks, and your basically done.  The only thing remaining would be to remove the old cooler hoses and brackets.   :)
Post by: trink2030 on May 08, 2012, 11:01:28 am
this absolutely works for the 454 as well. Just had to have the sac to beat on the base with a hammer to snap it free from the block.  After that it was an obvious installation.  Thanks for the additional help guys.
