73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: necromonger on December 19, 2011, 03:13:51 pm
Hi everyone.
Getting ready to tear down my 78 K30 here is what I need to know.The rad support is shot i would like to put a quad rad support in it's place is this possible also what else will I need to change.
Quad, as in stacked double lights?
On a 78 to do that you will need an 81/87 cowl panel, the plastic screen that goes under it, filler between the bumper,and the grill. Need 81/87 battery tray, hood, inner, and outer fenders. You will also need hood springs, and hinges. You will need to cut the hinges into the cab's cowl. You will need to swap in the 81/87 and up wiper transmission assembly. Plus all the lights, the wire harness, and grill parts.
So in other words it can be done but it be cheaper to get a replacement radiator support.
thanks
pat
I think I will look for a new 78 rad support I just hope I can find one.Thanks for the info.
Capt. sells those too.
Here is a link.
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=4144-320-73&Category_Code=7387FC (http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=4144-320-73&Category_Code=7387FC)
