73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: superior82 on January 01, 2012, 06:18:03 pm
I have a 1982 Chevrolet C20 that I bought from a friend a few months ago. I yanked out the original vinyl floor mat and found rust on the passenger side floor. I pulled kick panel that has a rubber flap with a vaccum tank on the passenger side and discovered the water was dripping through the oval opening. I popped the hood and after some time I finally found out that the water is getting into the rubber where the hood hinge bolts to the firewall and dripping into the cab. I got a new gasket from for the oval opening on the inside of the cab where the rubber flap goes. I just dont think that water should be running down through there. What should I do?
Im getting water in the cab on the right side floorboard! I can't believe I did that.
There is a bulletin on this. I've posted it on here before if you try using the search function. I'll see if I can dig it up too
http://forum.73-87chevytrucks.com/smforum/index.php/topic,22630.0.html
