General Site Info => General Discussion => Topic started by: zieg85 on February 11, 2012, 09:48:03 am
Title: How tight is tight enough???
Post by: zieg85 on February 11, 2012, 09:48:03 am
I have been wondering this question for a while now and just read another thread on it and I thought I would ask.  When hangers or other items, such as in 4x4 conversions are done and stuff normally riveted from the factory are now bolted instead.  Using grade 8 bolts how tight is tight enough?  Is there a general rule per size of bolt in ft/lbs or just torque it to your blue in the face?  My stuff is like putting the front stabilizer brackets on the frame which is not as critical as bolting shackle mounts...
Title: Re: How tight is tight enough???
Post by: VileZambonie on February 11, 2012, 09:54:22 am
Great question Zeig... Let me dig up the post we had on this a while back. It included a chart of standard torque values based on tensile strength, pitch etc. Standby
Post by: VileZambonie on February 11, 2012, 09:56:33 am
http://www.zerofast.com/torque.htm
http://forum.73-87chevytrucks.com/smforum/index.php/topic,14811.msg115111.html#msg115111
http://forum.73-87chevytrucks.com/smforum/index.php/topic,10704.msg77203.html#msg77203
Post by: zieg85 on February 11, 2012, 12:54:08 pm
Awesome, you da man!!!  Must have missed that thread last year.  I am gone one week a year in January....  Thank you Vile
Post by: Blazin on February 11, 2012, 09:12:40 pm
I use the two grunt method allot!
Post by: beastie_3 on February 16, 2012, 03:01:41 pm
Are those links in the tech section?
Post by: Lt.Del on February 16, 2012, 07:32:24 pm
Quote
I'm from the country.  Tighten it til she breaks, then you know how tight you should tighten the others.
Post by: Blazin on February 16, 2012, 07:53:44 pm
Yup, just a little more, eh maybe a little more. Oh crap, I guess that was to much!
Post by: zieg85 on February 16, 2012, 09:06:20 pm
That is why I asked.  I have broken my share of grade 8 bolts and the last thing I want to do is tighten it to much and have it fail under use...
Post by: Sartobuilt on February 16, 2012, 09:13:48 pm
I usually go a quarter turn before it breaks.
