73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: INJUNTOM on March 21, 2012, 06:38:54 pm
I've always had a hard time getting gas in either tank on this thing - have to let it dang near trickle in. Anything more and it will spill over and kick off the nozzle.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,22964.msg190325.html#msg190325
http://forum.73-87chevytrucks.com/smforum/index.php/topic,16646.0.html
Maybe this will help
It is the way they are designed and what filler nozzle at the pump you are using. Some on here have used filler tubes off a diesel truck and say they work better. My plan on my 74 when I get to that stage is make my own, I will more than likely have to experiment with a couple of different ones, but I have had if with the trickle fill up. I have had mine apart several times, no clogs or vent problems, just wont take gas very fast.
i know on mine i have to use a certain fuel nozzle the ones that just have the rubber cap no ribs. the newer "eco friendly" ones dont work and you have to have the nozzle hang out 1/2 way
I just put the nozzle in and pull it back out a little and it fills fine.
