73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: FrankenTruckSS on April 12, 2004, 06:47:00 pm
Title: ball joint problem
Post by: FrankenTruckSS on April 12, 2004, 06:47:00 pm
Hey, my truck is registered as a 74 c10, because thats what it has for a frame, but it was converted to 4x4 at some point in its life and the 350 was swapped for a 305 H.O. out of a monte carlo SS. I need to replace the ball joints and have no idea what to get because i dont know if that was changed when it was converted to 4x4 or not. Only the front ones are gone, and i was hoping to have them fixed by the end of next week. Thanks in advance for your help.
Title: Re: ball joint problem
Post by: roundedline on April 12, 2004, 06:19:00 pm
Is it still 4WD?  If so you don't have balljoints but kingpins.  All parts are specific to the axle.  Once you find out what you have you can get the parts a lot easier.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: 73K20 on April 13, 2004, 06:22:00 am
Unless it is a Dana 60, he has ball joints.
1973 K20 - 350/465/205
Post by: roundedline on April 13, 2004, 01:14:00 pm
My bad, that is correct.  I had Dana 60 on my mind....
Project Su
Jimmy 2WD Project
Title: which axle?
Post by: FrankenTruckSS on April 13, 2004, 04:24:00 pm
what is the easiest way to figure out what axle i have?
Title: casting #s
Post by: FrankenTruckSS on April 13, 2004, 05:50:00 pm
ok, i just went out a few times and layed in puddles in my driveway trying to find casting numbers and the BoM number and whatnot. I was not able to find the model number or BoM, but i did find 3 other numbers (this is the front axle):
side of differential case: C113 or C173 (not sure which,  but i think it is C113)
Other side: GM5 (which, according to various websites means it is a 3.89:1 ratio rear axle)
and on the bottom right near the edge was 14038378
It is just the front balljoints that need to be replaced, so this is all the front axle. What threw me was when i found out GM5 was rear axle. So i am not sure if the differential case was switched or what. Also, i was looking on the axle tube for other numbers, but i couldnt find any. I am not sure if maybe when the other guy who built most of it put all the rancho stabilizers and whatnot on he may have welded over the numbers. I will try and check next time it is a nice day out and i have time to see it i can locate any other numbers. If that is all i need, then thats great. Anyone know whats goin on here?
Title: Re: casting #s
Post by: roundedline on April 13, 2004, 06:20:00 pm
If it is a Dana front axle the bill of material number will be stamped on the right hand side axle tube. It should be like 603....., 604.... or 605.....  At the flange where it meets the axle (where the spot weld is) on the right bottom flange, looking at the housing cover, it might have a 44 stamped in the flange.
You could also use the chart listed here:
www.coloradok5.com/axleguide.shtml
Project Su
Jimmy 2WD Project
Title: re
Post by: FrankenTruckSS on April 14, 2004, 11:42:00 am
yeah, i checked for the BoM number and model number. I think it is a GM axle because i couldn't fimd the "44" on the flange, but i found GM5. The rancho suspension components for steering and whatnot i think were welded over the BoM # if there is one, otherwise they were welded very close. If it is a GM axle, how do i find out which kind?
Title: Re: re
Post by: FrankenTruckSS on April 14, 2004, 02:23:00 pm
It is a Dana 44, that chart helped, thank you. So do i need teh BoM to know which balljoints i need, or are they all the same for Dana 44?
