73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Highs (Raising/Lifts) => Topic started by: robertchevy77 on August 13, 2004, 04:15:00 pm
Title: question on lift and suspenison
Post by: robertchevy77 on August 13, 2004, 04:15:00 pm
I WAS TALKING TO SOME MECHANIC BUT HE WAS IN A BIG HURRY SO ALL I HEARD WAS SOMETHING ABOUT ITS BETTER TO RAISE THE BODY THEN TO MESS AROUND WITH THE SUSPENISON BUT I THOUGHT THEY WERE THE SAME THINK ITHOUGHT IF U WANT I RAISED THEN U HAVE TO SCREW AROUND WITH THE SUSPENSION IS THIS TRUE????
Title: Re: question on lift and suspenison
Post by: roundedline on August 13, 2004, 09:12:00 pm
He is talking about a body lift.  Personally, I wouldn't use one, but that is just my opinion.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: 1976Scottsdale on August 21, 2004, 09:44:00 pm
I have a 1976 C10 Scottsdale that is in great shape, but the springs are a bit worn, I also have a 1980 Big Ten that has a shot body but great springs all around.  Does anyone know if it is possible to remove the springs from the 1980 and install them on the 1976?
Post by: roundedline on August 23, 2004, 04:19:00 pm
Are they both 2WD?
The Big 10 has HD springs that are 56" long.  Unless the '76 has the HD springs, you won't be able to swap them.
Project Su
Jimmy 2WD Project
Post by: 1976Scottsdale on August 23, 2004, 10:10:00 pm
No idea.  If nothing else, I may just consider a body swap.
Post by: bigblue86 on August 28, 2004, 10:55:00 pm
robertchevy,
personally I think that a suspension lift looks better, but a body lift is easier.  all it consists of is removing the old body mount bolts, adding the lift block spacers (usually 2-3") and reinstalling the new bolts supplied with the lift kit.   you might need to alter the bumper brackets unless you dont care that the bumpers sit lower now that the body is lifted.  There may be a few other small alterations like checking clearance on your fan shroud, but it is a pretty straight forward thing.
