73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: 1984gmchighserria on May 10, 2012, 09:12:56 am
Does any one know the. 2 bolt sizes of the 1985 700r4 np208 bolt to the crossmember?
Does it have welded in nuts on the cross member ?
No, should it.
If it does not, just use 3/8" or 7/16" if it will fit with some nylock nuts so they wont back off.
Its the bolts that bolt the cross-member to the transmission.
Ah, I am out of town with the wife, but if nobody has answered by tomorrow when I get to work, I will pull my 208 off the shelf and get you the bolt size and thread pitch.
So I checked my 208 on the shelf when I got into work, seems that I do not have the bolts for the crossmember, someone else is going to have to chime in with the size.
Thanks aways blake74
