73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: rusty but trusty on May 11, 2012, 07:35:54 pm
Title: fill plug on rear diff stuck
Post by: rusty but trusty on May 11, 2012, 07:35:54 pm
OK i rely wished i had checked this before i drained the gear oil but i didn't and have the pan back on and everything and went to loosen the bolt and could not any advice
Title: Re: fill plug on rear diff stuck
Post by: VileZambonie on May 11, 2012, 08:00:27 pm
Why not? Make sure it's clean and put the drive all the way in. Put a little muscle into it
Post by: Lt.Del on May 11, 2012, 10:49:57 pm
put a 1/2" drive ratchet directly in the square slot.  No sockets or anything. Put a pipe over the handle for extra leverage or use a hammer and wack it a few times ensure you're are going counter clockwise with it.  It'll come out.
If not, time for a propane torch to warm it up, then repeat.  Don't go too crazy w/ the propane torch, differential oil is oil after all.
Post by: Fairlane514 on May 11, 2012, 11:26:48 pm
How about some PB Blaster on it and let it soak in for a little bit.
Post by: thirsty on May 12, 2012, 07:36:50 am
I had one that was rounded off and couldn't get anything into it solid enough to turn it out. I ended up welding a bolt into it and it came right out. I replaced it with a square plug so I could use an eight point socket on it next time.
Post by: Blazin on May 12, 2012, 07:55:38 am
Give it a good swat or two with a hammer. Spray it with weasel pee, and let it soak for an hour or so wont hurt. Use a ratchet or breaker bar directly on it. Heat around it with a torch if you have to. Heating it plenty hot wont hurt it.
Post by: VileZambonie on May 12, 2012, 08:23:06 am
It is 3/8" drive. You are better of with leverage over anything else. You can easily strip it out if you are not in there all the way. http://www.stanleyproto.com/default.asp?TYPE=CATEGORY&CATEGORY=J9500B&strSiteName=PROTO&strDefaultCatalog=PROTO these work great for removing stripped plugs
Post by: rusty but trusty on May 23, 2012, 08:44:36 pm
thanks guys the heat and weasel pee did the trick
