73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: 1984 K20 on December 15, 2004, 09:22:00 pm
Title: Bolts and Hardware
Post by: 1984 K20 on December 15, 2004, 09:22:00 pm
Does anyone know where I can get all the bolts and hardware I need to attach the front and rear axles.
Thanks
Title: Re: Bolts and Hardware
Post by: RSBAD454 on December 15, 2004, 08:42:00 pm
can you elaborate a little more......what bolts/hardware do you need?
Toys are my game
Post by: 1984 K20 on December 16, 2004, 09:11:00 pm
Well I have a bare frame with only the brackets that are riveted on to it. I need the shock mounting bolts,front sway bar bolts, and I need all the bolts that connect the springs to the hangers and shackle assemblies. I also need the bolts that mount the cab, box, radiator, and the rest of the drive train, but I'm not to the point of putting the body and drive train on yet. I hope this helps.
Post by: roundedline on December 31, 2004, 01:29:00 pm
Any local Bolt store should have the bolts/nuts you need.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: 1984 K20 on December 31, 2004, 06:48:00 pm
I'm gonna go with   and some of Lawson's hardened steel grade 8 bolts for the hardware. Thanks
