General Site Info => General Discussion => Topic started by: RicoTizzio on June 16, 2012, 02:48:00 pm
Title: Driveshaft
Post by: RicoTizzio on June 16, 2012, 02:48:00 pm
Installed a 700 in my 84 Chevy that had an overdrive trans from the factory. Should my org shaft fit perfectly in there or will i need modification. Is there a junk yard fix lol
Title: Re: Driveshaft
Post by: bake74 on June 17, 2012, 04:37:14 pm
     Are you talking about the A833 4 speed overdrive unit ?  If so then no, your driveshaft more than likely will need modifications unless both transmissions were close in length.
Post by: RicoTizzio on June 22, 2012, 01:14:15 am
That i don't know,i was going by the factory book that came with it n using the vin numb
Post by: slammed79 on June 22, 2012, 11:00:35 am
Drive shafts are almost impossible to find in junkyards here. One of the local shops quoted me $350 for a steel, one piece shaft, 57" long.
Try craigslist or have one made.
Post by: RicoTizzio on June 22, 2012, 11:04:40 am
Thanks will do
Post by: Irish_Alley on June 25, 2012, 02:42:30 am
the junk yard i worked at we had a rack just for drive shafts. the only problem is trying to match the yokes up
Post by: RicoTizzio on June 25, 2012, 07:06:10 pm
My factory yoke will go in the tail but its rusty so id like to clean it any ideas
Post by: thirsty on June 26, 2012, 08:18:16 am
Those are made from some pretty good steel. It takes a lot of rust to make them pitted. Clean it up with something like brake-kleen then use about 180 grit paper to get most of the rust off without making it shiny. Switch to emery cloth and polish it up. Check it for pitting or damage to ensure it doesn't eat your seal up. I had to do the same thing to mine after it sat for a long time in a shed and rusted. I was upset when I found it that way but after 10 minutes of work it was good.
Post by: RicoTizzio on June 26, 2012, 02:39:57 pm
Sounds like a plan. But will the same steps work on the inside of the yoke
