73-87 Chevy _ GMC Trucks => Blazers/Jimmys => Topic started by: cmpayne on June 19, 2012, 08:39:20 pm
Title: Need help Steering box Frame= not good.
Post by: cmpayne on June 19, 2012, 08:39:20 pm
Hello all,
I need some help and maybe some of you can. I have a 87 K5 blazer and it pulled the steering box through the frame and ripped it. What would be the best way to fix it or is it past repair? Hopefully the pics will help.
Title: Re: Need help Steering box Frame= not good.
Post by: thirsty on June 19, 2012, 09:01:22 pm
There is a plate made for that area.
That looks pretty rough though. Maybe a welder should take a look at it.
Post by: bd on June 19, 2012, 10:14:46 pm
OUCH!!!
Anything can be done if you have the time, money and resources.  Your biggest repair issue in this case is that the cracks radiate along/through the rail radii and propagate completely across the width of the flanges.  The radii and flanges provide the structural integrity, strength and torsional stability to the frame.  The plate Thirsty refers to is designed to address star burst and tear-out around and between the bolt holes; they aren't quite large enough to adequately correct a failure that has progressed as far as yours has.  You'll need to fabricate your own plates.
Jig and clamp the broken frame back into its original shape and position; drill, weld and dress all the cracks so the frame assumes its original shape, appearance and thickness; then fabricate custom 3/16"-thick plates for the outboard and inboard faces and both upper and lower flanges.  You could add additional strategic support between the flanges inside the frame.  The problem with doing this is that it makes that section of the frame extremely rigid and concentrates stress in adjoining parts of the frame, predominately just aft of the existing failure; so you could develop additional cracking with hard use.
Because of the strain imparted to a 4x4 gearbox-to-frame mounting, any repair solution will require additional bracing to prevent the gear from tin-canning the frame again in the future.
Take a look at the linked thread to get some ideas and adapt it to your situation...
http://forum.73-87chevytrucks.com/smforum/index.php/topic,23828.0.html (http://forum.73-87chevytrucks.com/smforum/index.php/topic,23828.0.html)
Post by: cmpayne on June 20, 2012, 06:20:43 pm
Thank you for the help.
Post by: bake74 on June 21, 2012, 08:15:46 pm
     As what bd said, only thing I would add is this is not a repair that should be done from a person who only has welded at home as a hobby.  You need structural welds, unless you are a professional welder I would consider taking it somewhere or find someone who can come to you.
Post by: cmpayne on June 22, 2012, 10:13:49 am
As of right now its looking like I may have to scrap the truck. No shop in my area will touch it. And I can't weld nor will I try on something like this.
Post by: bake74 on June 23, 2012, 09:16:39 am
     Try looking for a replacement frame.  Where are you located ?
Post by: thirsty on June 23, 2012, 04:17:54 pm
I agree. If your truck is good other than that then replace the frame instead of scrapping it.
Post by: cmpayne on June 23, 2012, 04:40:28 pm
I do happen to have another frame but it needs some minor welding as well, two cuts in middle of it and body mounts need some repair. But I know I can't weld for one I never welded so I know I can't do it and two I don't have a welder or a 220 outlet to plug one into. Bake74 I'm located in imperial Missouri. To be honest I don't think I can scrap it, it just might be sitting for a very long time. Thanks for the help and input.
Post by: nitewolf on June 23, 2012, 06:56:09 pm
You can get a 110 welder. thats what I use and sense I don't have a shop to work in I just have to use flux core wire so I don't have the extra cost of gas.
Post by: Edahall on June 24, 2012, 05:53:35 pm
I faced the same situation as you on my 1982 Suburban.  This is definitely very shade tree but I ended repairing mine with some very thick straight grain hardwood.  I cut the hardwood to fit inside the frame and bridge across the crack.  I then used Bondo to fill any voids between the hardwood and frame.  Afterwards, I used lag bolts to attach the steering box back to the frame.  The repair was a success and has lasted thousands of miles without issue.
Post by: thirsty on June 24, 2012, 07:37:10 pm
Please don't do this.
If you can't swap frames then maybe look into a certified welder that can repair it. Over the road trucks, dumps, and all sorts of trucks have their frame dimensions changed more than you would think. This can be repaired, you just have to find the right guy.
Post by: bd on June 25, 2012, 01:12:11 am
x1000
Approaching a frame repair in this manner endangers everyone!
Post by: bake74 on June 25, 2012, 07:21:12 am
     Also do not do this.  A 110v welder is not for frames.  It's duty cycle and penetration capabilities is not enough to do a frame.  I can understand no one wanting to touch your frame with the bad steering box rip, but the second frame you have does not sound that bad.  If you strip it and take it somewhere I bet they will weld it up for you, and this time have a weld in brace for the steering box welded in place and save yourself some headaches down the road.
Post by: Blazin on June 25, 2012, 05:06:09 pm
No 110 welders, no flux core crap wire, and NO WOOD OR BODY FILLER in your frame.
We shorten, and stretch big rigs, and trailers all the time. You don't have to go to a welding shop. Most likely they are going to say no because of the liability. They are probably very capable of repairing that, but if for some reason you were to get in a wreck, hurt or kill someone friend or stranger, and the frame had been repaired. It would be there but in the sling! There are plenty of capable guys that do hobby welding that could fix that frame, or section in a piece from another frame.
If it were me I would section in a new / used piece. That way you only have to remove the LH inner fender.
One more thing before repairing that frame look it over with a fine tooth comb. Is it worth repairing? You might find other problems with it. Then it would be better to swap your drive train, suspension, and or body onto another frame.
Post by: Edahall on June 25, 2012, 06:27:35 pm
x1000
Based on personal experience, I could turn that statement around and say having a frame welded by a certified welder endangers everyone.
Post by: topp on June 26, 2012, 09:54:55 am
Hardly....
Wood is not strong enough to handle the stress put on the frame from the steering forces.....
Properly welded metal is....
Post by: Blazin on June 26, 2012, 11:23:31 am
How do you figure that having a frame correctly welded endangers everyone?
Post by: Edahall on June 26, 2012, 06:55:37 pm
I had my cracked frame welded by certified welder and it failed after several years of use.  Luckily, it re-broke in a parking lot.  The whole steering box ripped out from the frame leaving a gaping hole in the frame.  That said, the crude shade tree repair has outlasted the previous high tech repair by a long shot.  I have full confidence that it'll never fail because if I didn't, I wouldn't be driving it.  However, the vehicle's next destination is the crusher.
Anyways, I don't want or intend for get everybody excited about the repair.  It obviously is not an engineered or certified repair so take it as it is.  However, I do assure everyone that it was well thought out and overly built to not endanger everyone.  Worry about the speeders and drunk drivers if you need something to worry about.
Post by: Blazin on June 26, 2012, 09:31:15 pm
Ive been building and modifying log bodies, chips trailers, truck frames, lengthening, and shortening them for years. I have never had one fail yet. Log bodies do crack occasionally from stress. Sounds to me like the certified welder didn't have a clue.
I myself am not a certified welder. We have a certified welder that brings his truck to us for repairs, and some service work. He has looked at my welds, and said they are better than alot of guys that are certified.
Post by: cmpayne on June 27, 2012, 06:06:45 pm
Thanks for the input. i'll be looking for someone to weld my other frame and i'll have another  project to do. any tips/hints when i start to remove the body?
Post by: thirsty on June 27, 2012, 07:13:26 pm
Use a breaker bar on the body bolts instead of an impact wrench. It will reduce the chance of spinning the nut in the welded on collar inside the body.
Post by: bake74 on June 28, 2012, 09:16:24 am
     Keep everything labeled and organized.  Nothing worse than taking something apart and not remembering how it goes back together.   :o
Post by: Cabcorner on September 26, 2012, 05:43:17 pm
                   I would love to see pics of the hardwood repair.
