General Site Info => General Discussion => Topic started by: Low87 on June 26, 2012, 02:09:54 pm
What are the bolts called that hold the heater box in place? They've got a clip on the interior side that attaches to the under dash heater box, then they pass through the firewall. I think there are 4.
I bent a couple of mine changing the heater core a few months ago. Thought I'd go ahead and replace them all, but can't find them anywhere.
Could you post a picture of one, they might be J-Nuts.
Not any time soon. I was able to use them to reassemble everything, so they're all back in place and a PITA to remove. Don't want to tear it apart til I'm ready to replace those. I'll dig online to see if I can find a picture.
I don't know of a source for finding those. Did you bend the actual bolt?
I did. I couldn't see the bolt from where I was at, wrenching away. Did know til too late that the nut has stuck and I was twisting the bolt instead of threading the nut. Might have to be a junk yard item.
They are j clips. Had the same problem... Dealer discontinued... Just ended up making it up with a bolt and a clip and a lock nut
