73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: 84 chevy guy id on July 14, 2012, 10:06:37 am
I want to add 2 gauges to my cummins/chevy crew cab dash, need a boost gauge and a pyrometer. Two essential items when you start turning up a diesel. My plan is to move the right side ac vent down where the radio currently resides and add the two gauges to the spot where the vent was but make it look factory using the 2 holes with the gauges recessed like the other gauges are. I am going to have air ride/assist on the front and rear suspensions so I needed an air guage also. I went to the truck wrecking yard the other day and scored a guage cluster with the air gauge in the lower left position. I also found a gauge panel with a 5000 rpm tach with the fuel gauge under it and a 100 mph speedo. I am going to have an overhead console and can put the radio up there so deleting it from the dash is not a problem. Does anybody have any pics of a dash with gauges put in the right side vent position? I did find a pic of what looks like a truck dash with those 2 extra holes added. I have seen a few where they made a plate and mounted them in the plate but I am after the factory look so I hate to do them that way. Any suggestions?
Sure would like to know what year/type you harvested that tach/fuel gauge from if you know. Thanks
I think it was a 78 chevy ten wheeler. Isnt the 100 mph speedo from 70's trucks? You can but a new tach/fuel gauge combo but the tach goes to 7000 rpm and I didnt want to use that with a motor that will only turn 3500 or so. Here is a link to the new one that I found. I would like to get one of these for my gasser pickup and blazer one day.
http://gmsportssalvage.com/?q=node/1530
Moving the AC vent down is going to be a chore. The duct work to that vent is all hard plastic. Not saying it can't be done though. It's just something to think about. You might try to use an adapter like the far right side vent has that will accept a piece of flex hose.
Capt is getting close to completion (I think) of gauge pod's for the a pillar. Might want to check in on that before going into this.
Waiting on the "proof" to arrive...
Here is an update on my gauge project. I cut the top two gauge hole piece out, then cut the vent section out and fitted the gauge piece in. Took it down to my friend Chris, who has a plastic welder, and he glued it together. He stuck the corners together with a little plastic then used a product called Fusor142 and ran a bead all around the back of the patched piece to strengthen it then he used his soldering iron welder tip and ran it around the seam on the face to smooth the seam then he hit it with a little sandpaper to clean it up a bit, and it turned out really good. Tonight I whittled on the vent piece I removed earlier and cut the radio spot out to fit it. The vent is recessed quite a bit more than the left side vent so I removed some of the depth to try and make it match, its probably a half inch deep now. The right side of the opening has a taper and its the wrong direction to sit in the bottom section so I cut the side and corner loose and heated it and pulled it over some so it more matches the right edge of the dash. The tricky part now is to get the slot filled it so it blends in good, will find out tomorrow. I really like the white face gauge faces that the place in Utah does so I called them today about all my gauges and they said no problem. I will have temp, volts, oil pressure and an air pressure gauge in the four stock holes with a 100 mph speedo and a five thousand rpm tach with the fuel gauge in it in the big holes, then a 60 lb boost gauge with a 1600 degree pyrometer in the two extra holes. I am getting autometer gauges for those two, then taking the bezels and glass lenses off so they can cover them to match the rest of the gauges. Should look pretty sweet! The next challenge will be getting the brushed stainless insert whipped up to cover the extra gauges, still thinking on how to do that one.
A few more
Looking good man.
