73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Fairlane514 on July 31, 2012, 09:56:31 am
Title: Bolt on wider rear end for 84 C10
Post by: Fairlane514 on July 31, 2012, 09:56:31 am
Is there a rear end that will be wider than the original that came in an 84 C10?   Can I find one to bolt in and have the rear wheels the same width as the fronts, while still maintaing the 5 lug bolt pattern?
 Sorry if this has been asked before, I did a search and didn't seem to find the answer.
Title: Re: Bolt on wider rear end for 84 C10
Post by: slammed79 on July 31, 2012, 10:17:39 am
Probably not bolt in. I think Dodge had a wider track width, but you'd need to mod the spring perches. What are you trying to achieve?
Post by: Fairlane514 on July 31, 2012, 10:25:26 am
Better gear ratio (I have a700R4), its either a 2.73 or 3.08 now.  Wider stance from behind.  It would be nice if it was a positraction also.
Post by: slammed79 on July 31, 2012, 10:32:44 am
You could pull a differential out of a stick shift truck, prolly be a 3.73 or 4.11. As far as a wider stance, I like some Mickey Thompson sportsman radials, that'll give you a pretty wide footprint. Just my .02
Post by: Fairlane514 on July 31, 2012, 11:00:44 am
Thanks for the information.  Right now I have the original 7 inch rally wheels with 255/60/15.  I guess an 8 inch would look a little better. I really like the look of the rally wheels.
Post by: Jason S on July 31, 2012, 11:39:37 am
I think the 88-98 Chevrolet pickups rear axle is slightly wider, although you'd  still have to move spring and shock mounts.
Post by: Fairlane514 on July 31, 2012, 01:43:57 pm
What about a 91 Suburban?
Post by: zieg85 on July 31, 2012, 02:02:03 pm
91 Suburban is the same width and will be a great replacement.  If the tracking width is a concern, get wheel spacers for the rear or run 15x7 up front and 15x8 in back with a little wider tire.  My $.02
Post by: Captkaos on August 01, 2012, 09:07:16 pm
The newer 88-98 C/K truck rearends are a little wider.  R/V rearends are identical.
