anyone know the stock measurement of the front coil for an '86 swb c10 2wd would be? i may need to get some new ones since mine look like they have been plasma cut...or are they supposed to be rough cut on the ends?? i'm hoping the bozo before tried to cut the coil and heated them up so that would explain to me why the inside of my tires wear out prematurely.....gracias....
The end will be sheered smooth. As for measurements, they are not going to be the same as compared to a brand new set. Springs settle over time and they settle differently. Giving you a free height measurement from a new set and from a used set will give different results.
Is the truck lowered? Chris Lucas
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
thanks alot...now to find out where to get some new springs....God im stoked to finish up my truck....she's just sitting pretty on the drive crying (oil)...
Most of the big chain stores can get you springs. Where are you located?
Project Su
Jimmy 2WD Project
well, i bought some stock height coils. when i got them, they are the same height as the ones i had in there (just painted new black now!!) now i'm this >> much closer to getting my baby running...
