73-87 Chevy _ GMC Trucks => Electrical => Topic started by: p7387 on September 30, 2012, 01:07:37 pm
any opinions on diagnostic / troubleshooting code readers, are they worth getting?
if so any good particular ones?
my application is a 87 r10 305 tbi
thanks
IMO for the OBD 1, jump your terminals and read the codes. Once you know the codes with the internet and different forums I have found all the answers so far. My $.02
thanks zeig
im still on the learning curve. i have the general chevy truck/gmc manual that covers the wide range of years up to 87, in there i see the section that relates the number of times/patterns of the check engine light blinking to certain codes. is that what you are referring to?
Do you have a smart phone or an iPad?
unfortunately no, is there an "app" for that?
is the diagnostic connector that plug that looks sort of like a old parallel printer plug under the dash on the drivers side? and are the A/B terminals clearly marked to avoid jumping the wrong terminals?
Image courtesy VileZambonie...
Yes there is an app for that. In fact anyone who has an iPad or smart phone be it iPhone or Android you have a plethora of choices starting at $15 to have scan tool capability.
For an 87, get a used Tech 1 or use winALDL and a obd cable.. Or if you just want the codes, a paper clip plugged in to the A an B terminal of the ALDL...
