73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: winky on October 18, 2012, 07:59:53 pm
looking to upgrade my running gearneed help on deciding what to go for... here are some specs..
350 engine (building a beefed up 350 for it though)
700r4 trans, would like something more reliable (truck is purely a play toy not worried about gas consumption because of no overdrive)
37" super swapers
208 t case
stock front and rear end i believe 3.73 gears?
6" susp lift 3" body ( i know this doesnt really affect too much but maybe pinion angle would be worse on something?)
any ways i want every ones input on what i should buy for my truck.. no im not rich and i dont have a ton of money but i would rather save up and buy the right stuff than have to tear down my truck every time i go play in it..
i mainly play in the mud but i DO have a heavy foot lol, also i tend to be the only guy with decent mud tires around here so i play recovery a lot lol so i want something that will hold up and not break but also dont want to kill my check book. i would appreciate any help and input
As long as it is slippery mud, you should be fine especially if you are only and occasional recovery truck.
If the 700R4 is old, and worn out, rebuilt it would definitely be reliable.
I found this if it helps ya out. Gear Ratio
Size 3,31 3,42 3,55 3,73 3,91 4,11 4,27 4,56 4,88 5,13 5,29 5,38 5,71 6,17 7,17
30 2410 2490 2584 2715 2846 2992 3109 3320 3553 3735 3851 3917 4157 4492 5220
31 2332 2409 2501 2628 2755 2896 3008 3213 3438 3614 3727 3790 4023 4347 5051
32 2259 2334 2423 2546 2669 2805 2914 3112 3331 3501 3610 3672 3897 4211 4894
33 2191 2263 2349 2469 2588 2720 2826 3018 3230 3395 3501 3561 3779 4083 4745
34 2126 2197 2280 2396 2512 2640 2743 2929 3135 3295 3398 3456 3668 3963 4606
35 2065 2134 2215 2328 2440 2565 2664 2845 3045 3201 3301 3357 3563 3850 4474
36 2008 2075 2154 2263 2372 2493 2590 2766 2961 3112 3209 3264 3464 3743 4350
37 1954 2019 2095 2202 2308 2426 2520 2692 2881 3028 3123 3176 3370 3642 4232
38 1902 1966 2040 2144 2247 2362 2454 2621 2805 2948 3040 3092 3282 3546 4121
39 1854 1915 1988 2089 2190 2302 2391 2554 2733 2873 2962 3013 3198 3455 4015
40 1807 1867 1938 2037 2135 2244 2331 2490 2664 2801 2888 2937 3118 3369 3915
44 1643 1698 1762 1851 1941 2040 2119 2263 2422 2545 2626 2670 2834 3063 3559
The tire size is the column running down the left and gear ratio is running across the top. All the other numbers are the rpm at which it would be at 65 mph.
Thank you, I found a set of one tons for $1200 ( wife will probably flip lol)
That isn't that bad a price if it is a good D60 and 14B...
Ok so the guy said he was interested in trading. I have some 37" tsl boggers about 75-85% tread on 15" aluminum bullet holes would that be an even trade or what? Was wanting some input, what would y'all ask for if you were in my shoes
Try it and see. I don't know what yours look like, so...
(http://i1269.photobucket.com/albums/jj582/josh_brooks2/4AA88076-F722-46DE-BD4E-5DAE546254D9-1102-0000015C3AB72403.jpg)
