73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: hillsmith on October 20, 2012, 05:34:40 pm
Title: Dropped Spindle Broke 1986 C10
Post by: hillsmith on October 20, 2012, 05:34:40 pm
So I spend the day on my truck which has been in dry storage for years, Did a brake job, tune up, changed all the fluids etc. A few test drives getting the TV Cable adjusted and finaly its a driver again. So backing out of my driveway the front spindle breaks and locks up the tire. I live on a private drive so no big deal and was able to repair it but having a spindle just shear off has me pretty concerned about what to replace them with???
Is this just a fluke deal or has this been an issue? A search turned up nothing. I am feeling pretty lucky today that this happened while not moving in my driveway. I can imagine the damage had this happened on the freeway.
Title: Re: Dropped Spindle Broke 1986 C10
Post by: hillsmith on October 20, 2012, 05:36:50 pm
Damage Photos
Post by: slammed79 on October 20, 2012, 06:17:24 pm
Thats crazy! I've never had that happen on 8 or 9 lowered vehicles. I'd call it a fluke.
Post by: zieg85 on October 20, 2012, 07:28:46 pm
If it were me I would replace both.  Fluke or not that is bad steel IMO...
Post by: hillsmith on October 20, 2012, 07:36:20 pm
I am replacing both spindles for sure, in fact this may be the time to swap out the whole front end for a Scots or Porterbuilt style since I never liked the way this truck rode or sat anyways. I put a stock spindle back on it for today and its parked until I sort out which way to go.
Post by: 454Man on October 20, 2012, 08:12:33 pm
Out of curiosity what size wheels were on?
Post by: hillsmith on October 20, 2012, 08:23:20 pm
PS Engineering 17X7
Post by: bd on October 22, 2012, 01:48:51 am
That looks like ductile fracturing (stretching distortion of metal grains as opposed to simple breakage).  From your images, the crack appears to have grown gradually to ~20% through, before catastrophic failure occurred.  Can you tell if the radius limb had a smooth transition or a sharp termination where it met the small diameter of the spindle prior to fracturing?  Do you see any inclusions or tiny voids in the fracture surfaces?
Post by: hillsmith on October 22, 2012, 09:38:25 am
There is a sharp termination at the taper which may have contributed to the location of the break. There does not appear to be any other visible flaws in the surrounding metal. Looks like poor metal quality or a lack of heat treating or hardening on the manufacturers part.
Post by: bd on October 22, 2012, 11:55:18 am
I've read that Bullett was distributed by AIM.  There's no historical record of complaints or failures that I could find either, so likely just a fluke or part of a limited bad batch.
