73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: project1 on November 16, 2012, 08:49:08 pm
Another question about my 86 chevy already purchased outer rocker panels and cab corners, but wanted to know what the name of the piece or if there is one availble for replacing part way up the outer seat hump (rocker panel side) looked around at different sites for panels but not sure what to order, would the inner rocker panel cover some of the seat hump? Tried uploading a pic but the file size was to large if a pic is needed I will try a little harder!
Yea some pics would be helpful. Here is 2 replacements you can use. One or the other should be what you need to repair what you are working with...
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=0850-227-228&Category_Code=C1
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=0850-301-302&Category_Code=C1
If the pieces that hotrod24 linked to aren't big enough you will have to use flat stock.
Finally got a pic loaded
Yea you should be good with this inner rocker replacement...
