73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: WUTSAV8 on January 15, 2002, 03:29:00 am
Title: 3/4 ton to 1/2 ton?
Post by: WUTSAV8 on January 15, 2002, 03:29:00 am
Has anyone done this before?
What problems have you run into regarding the brake lines and the driveshaft?
Also for your lowered 1/2 ton people, do you need to change the pinion angle much to compensate?
Thanks.
Title: Re: 3/4 ton to 1/2 ton?
Post by: weakmaxx on April 30, 2002, 03:45:00 am
woah, WHY???
not tryin to insult, but aren't you only weakening the axles?
maybe this has something to do with lowering kits?
maybe you should just sell the 3/4 ton and get a 1/2 ton, you will probly get money rather than loose it.
maybe i am missing something here
Post by: 4DR C10 on May 18, 2002, 04:40:00 am
They don't make a 1/2 ton Crew Cab truck.
But I just did. :P  Stay tuned for pictures..
I used to have a '75 C20.  The only problem was it rode like a truck.  It needed tons of weight in the bed to make it nice decent.
1/2 ton trucks are more passenger oriented and ride much smoother.  Also, most of the suspension products are for C10s.
Besides, I don't want a 8 lug 22 inch wheel ;)
Post by: 79Shortbox on June 29, 2002, 03:11:00 am
You're putting 22s on an old Chevy?????!!? *pukes and dies laughing*
Post by: 79GMC4x4 on June 29, 2002, 05:28:00 pm
Why no 22's on one of these?  Do yu ever go to shows?  Read magazines?
'79 GMC shortbed 454 th400 14 bolt FF NP205 Dana 60
Title: .
Post by: 79Shortbox on June 30, 2002, 03:31:00 am
Yucky!
Post by: bored and stroked on July 02, 2002, 03:06:00 am
yucky? Why exactly do you need to state a comment like that about someone elses taste in trucks. I too wanted to make a crew cab shortbed c10, droped with 20's. I think they look awsome.
Post by: Low87on20s on July 02, 2002, 10:42:00 am
I have an 87 swb that has been lowered with a DJM 5/5 and sits on 20x8s on the front and 20x9.5s on the rear.  I can tell you that my truck gets more attention with 20s on it than it ever did with smaller wheels.   Bigger is better.
