73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: jeffaj01 on November 26, 2012, 08:31:42 am
Title: np203 k10 blazer
Post by: jeffaj01 on November 26, 2012, 08:31:42 am
I found a th350 with an np203 transfer case mated forsale in my area. Is there a difference in the transfer case out of a 4x4 pickup and a k10 blazer? Mine seem to be acting goofy bouncing out of gear, and these are supposed to be ok. I'm sure this is the combo I already have, so I'm looking to just swap the pair out quick and easy. What would a decent price be to pay for this pair?
Jeff
Title: Re: np203 k10 blazer
Post by: bake74 on November 26, 2012, 10:03:44 am
     They are the same.  You said yours was bouncing out of gear, which one transmission or transfer case ?
     Both can be adjusted, you should try this first instead of just throwing another set in there.
Post by: jeffaj01 on November 26, 2012, 07:26:38 pm
It's got no front driveshaft in It, so I can throw it into 4 hi, I think. And it wont move for a while, then when it does it will just quit moving all together
Post by: bake74 on November 26, 2012, 08:58:55 pm
     Have you checked fluids in both ?
Post by: jeffaj01 on November 26, 2012, 09:10:52 pm
Checked it in the trans, seemed fine, didn't check the transfer, have never had to real with a tc,
Post by: jeffaj01 on November 26, 2012, 09:16:48 pm
Reckon this spring I will change the trans fluid and filter, and change the fluid in the transfer. Hopefully that will help. I just found these at what I thought was a decent price, and mine seem to be wishy-washy. Thanks for the replies
Post by: Blazin on November 26, 2012, 10:06:26 pm
Unless your NP 203 has been converted to part time it will not work without the front drivesahft installed.
