73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Highs (Raising/Lifts) => Topic started by: 454Man on December 05, 2012, 08:56:12 pm
Title: How much lift does this truck have?
Post by: 454Man on December 05, 2012, 08:56:12 pm
Anyone?(http://img.tapatalk.com/d/12/12/06/y5a7e5um.jpg)
(http://img.tapatalk.com/d/12/12/06/nedazu4y.jpg)
It has 33s
Title: Re: How much lift does this truck have?
Post by: clay7 on December 05, 2012, 09:02:40 pm
looks like maybe 2 inches to me. i have 4 and clear 35's pretty well
Post by: Big Katz on December 05, 2012, 11:42:13 pm
Looks like one of my trucks that doesn't any lift.
Post by: thirsty on December 06, 2012, 08:13:20 am
Looks stock to me. The fenders and the tires are going to get into an argument.
Post by: mehunter1 on December 06, 2012, 08:43:12 am
I agree with thirsty looks stock to me as well.  I had an 83 k20 back in high school and ran 33/12.5/16.5 on it with no rubbing.  How you ask.   Well it had heavy duty rear leaf springs so the back set higher already and then the previous owner had added some additional leaf spring pieces to the front to level it out.  Looked as though it had about a 2 inch lift, but set stock.
Post by: 454Man on December 06, 2012, 08:44:01 am
Ok that's two for no lift. The seller states that the trick is lifted. i'm trying to duplicate the look/lift on my truck. the back of my truck is that height but the front is lower. My truck has a factory towing package (sits higher in the back). For my 2wd what are my options for lifting the front. No hard off roading, just couple of bumps to my fishing hole.
Post by: pholliday1 on December 06, 2012, 10:04:29 am
How bout 3 for none. Looks like one speed bump and the fenders will go flyin
Post by: zieg85 on December 06, 2012, 10:35:29 am
Big block 1 ton springs are going to make is sit up the highest in the front end of a 2 wheel drive truck.  http://forum.73-87chevytrucks.com/smforum/index.php/topic,25053.0.html is my one ton extended cab, sits perfectly even and with slightly larger tires would give you the look you are going for I believe
Title: Re: Re: How much lift does this truck have?
Post by: 454Man on December 06, 2012, 10:54:00 am
Great! So its an easy swap. figure I will do ball joints and such while i'm there swapping springs. Guess ill keep my eyes open for some 1 tons parting out
