73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 78chevyshortbed on December 12, 2012, 03:19:29 pm
Title: Engine Confusion
Post by: 78chevyshortbed on December 12, 2012, 03:19:29 pm
on my motor it is stamped as a GM 14010207 and CFD 207. anybody have any knowledge towards this. Need help on whether its a 350 or 305. i did research and the GM 14010207 states that it is a 350. but the CFD 207 states that the motor is a 305. Help?
Title: Re: Engine Confusion
Post by: bake74 on December 12, 2012, 06:11:59 pm
     Where are you getting the info that says its a 305 ?
Post by: 78chevyshortbed on December 12, 2012, 06:30:22 pm
I researched the CFD 207 and it says it's a 305.
Post by: VileZambonie on December 12, 2012, 06:32:11 pm
350
Post by: 78chevyshortbed on December 12, 2012, 06:34:30 pm
Now all I'm seeing while I'm researching is that it's a 350.
Post by: 78chevyshortbed on December 12, 2012, 07:01:30 pm
okay, if you go on nastyz28.com and click the link thing that says, QUICKLY IDENTIFY A CHEVY ENGINE CLICK HERE, and go to the suffix codes and fine CFD and it says its a 305. if i go on this sight actually, just 73-87.com and go to engine identification and find the GM 14010207 it says its a 350???
Post by: bake74 on December 12, 2012, 11:09:57 pm
     Are both of these numbers stamped on the engine ?  Not the head, and where are you finding the numbers Exactly on the engine ?
     Behind the drivers side below the head on the block is where you should be looking.
Post by: Captkaos on December 13, 2012, 12:48:06 pm
You cannot go by the suffix code, it is a 350.  Engine casting number trumps whatever is on the machined pad.  Is the Engine code stamped there?
