73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: theaddictedchef on January 21, 2013, 08:51:06 pm
Title: Cluster Help
Post by: theaddictedchef on January 21, 2013, 08:51:06 pm
I spent the day taking the dash apart.  I am posting pics looking for as much feedback and you guys are willing to give.
The aftermarket temp and RPM gauges were crap.  That is the best word I can use on here.  Neither was hooked up and the only that worked was the backlight.  The holes drilled in the firewall were horrible.  I am in the process of fixing that.
I am hoping you can tell me what is salvageable and what I need to start shopping for.  Can I buy a whole new cluster with gauges?  Is it smarter to keep the gauges I have and piece things together?  The gauges look to be in decent shape (not the aftermarket crap).  Another concern is the wiring harness.  It has been spliced into so many times that I can't tell what goes where, what works/doesn't, and where things go.  I will post some pics of that as soon as the light is better tomorrow.
Thanks guys!
Title: Re: Cluster Help
Post by: theaddictedchef on January 21, 2013, 08:54:06 pm
Here is a couple more including a picture of the old speaker.
In addition, there is an AC control switch that I have included.  Is this usable?  Should I replace this while I am doing this?  I would rather have a new one that I am sure works than getting everything back together and having to replace it anyway.  Do these go bad, or is it the connections/hoses/wires that go bad?
Thanks again!
Post by: Jason S on January 21, 2013, 09:43:59 pm
It's a 1973 correct?
The plastic ears on the cluster might be repairable, but I would try to find another plastic cluster housing (white part). The plastic housing that holds the gauges can be replaced with another non-tach gauge cluster and then using the printed circuit from your original gauge cluster, you can re-use your original gauges. You can also swap in a factory tach cluster, you'd want to find a '76 and earlier (I think '76 is the break). Whatever route you go, make sure the gauges are correct.  Some years of gauges do not swap with others.
The speaker is is a 4x10 (i think). Most likely that paper cone speaker is shot.  You can replace the speaker with a pair of three inch in a custom bracket and bridge the speakers, if you want to have an in-dash speaker. I made my own bracket out of sheet metal and mounted the 3" speakers to it.
The HVAC control you have is specific to 73-75 trucks. The factory a/c setup on these trucks is different than the '76-up units. The vacuum connections on the '76-up trucks are different, so its really easiest to keep what you have. The most trouble I've had out of mine was with the switch at the back of the control unit (the switch that the levers go into).  This switch controls the power supplied to operate the a/c compressor clutch (for a/c and defrost) as well as vacuum for the HVAC doors.  The electrical part of the switch has contacts inside that can corrode and there is also a plastic ramp inside the switch that can deform over time.  There are other GM cars that used the same switch (I think early to mid 70's Chevy Novas, Olds Omegas and the Buick & Pontiac counterparts). The switch at the back and the blower switch are all replaceable parts. So you would definitely want to keep the control unit, even if you happen across a replacement.
With your current setup, for MAX A/C you set the top lever at A/C and position the bottom lever all the way to the left at COLD (the blower will be on high no matter what fan speed you have it set on).  For regular A/C, you'd have the top lever on A/C and then move the bottom lever to make a comfortable temperature, blower fan speed is then selectable using the blower speed control switch.
Post by: DnStClr on January 22, 2013, 04:34:37 pm
Here's a complete cluster on eBay.
http://www.ebay.com/itm/1973-1987-73-87-Chevy-GMC-GM-truck-cluster-tach-gauges-bezel-/330861194546?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d08dd2d32&vxp=mtr
Post by: Jason S on January 22, 2013, 09:31:49 pm
That eBay cluster has the electric oil pressure gauge and the voltmeter.  The correct cluster for theaddictedchef's  '73 should have a mechanical oil pressure gauge and ammeter.
Post by: theaddictedchef on January 24, 2013, 03:55:38 am
Thanks guys!  Saw that cluster on ebay.  I'm watching it to see where the bidding goes.
Post by: bake74 on January 24, 2013, 07:27:51 am
Post by: theaddictedchef on January 24, 2013, 01:01:39 pm
I'm doing some checking on these cluster gauges and I am wondering......
What year bezel's will work?  I understand the cluster gauges, but the bezel is painted red, and where the radio was installed it is cut.  Posting a pic so you can see what I am talking about.  Will '73-'87 work?  Or do I need '73-'76?
Thanks
Post by: Jason S on January 24, 2013, 07:53:01 pm
The '73 - '74 dash cluster bezel is slightly different where the headlight switch is concerned.  The '75 through '80 bezels were different in this area.  While a '73-'80 bezel will fit and work, the '73-'74 bezel is what is correct.  This may or may not matter to you though.
If you compare the area around the light switch on this '73 bezel to the '75 through '80 bezels, you will see what I'm talking about. I have a '75 bezel somewhere, but couldn't find it to take a photo for this posting (naturally)...
(https://lh4.googleusercontent.com/-ONAjEUlcZ7s/UQHcy2BLLyI/AAAAAAAAAt4/1_pW-cJ-IZ8/s400/DSC04702.JPG)
If you intend to install a single DIN radio (late style aftermarket radio), then you may just want to look into painting/refinishing your current bezel.  If you want to use the old style two-knob radio, then you'll need an uncut bezel.
Post by: theaddictedchef on January 25, 2013, 12:51:15 am
Thank you for picture.
I am going to post a pic of the one I have now and you will see what I am talking about.  Whoever did the work on the interior was a hack.  The more I find, the more I am disappointed in the interior work from the previous owner(s).  The engine, tranny, and 4x4 is in perfect shape, but the interior needs some help.
Thanks again for all the replies!
Post by: theaddictedchef on January 25, 2013, 01:49:11 pm
Posting some pictures so you can see my bezel and give some direction or advice.
Couple of clusters on CL here locally but not sure if they will fit.  One from an '81, the other is an '84 I think.
Any help will be appreciated.
Post by: Jason S on January 26, 2013, 09:55:26 pm
Did you post a photo in this thread?  Nothing is showing up.
Post by: theaddictedchef on January 27, 2013, 04:19:06 pm
Sorry about that.
Post by: theaddictedchef on January 27, 2013, 04:19:45 pm
Here are the others
Post by: bake74 on January 27, 2013, 04:44:13 pm
   The right side of that under the radio is missing, If it was me I would replace the cluster cover at least, unless you can live with how it looks.
Post by: Jason S on January 28, 2013, 10:28:51 pm
Your bezel definitely has had better days.
The '81-up gauge bezel can work, but if I remember right, it just doesn't fit right at the top when using the 73-80 padded dash.
Check with the site administrator, CaptKaos. Also, if there are any salvage yards in your area, look in the 73-80 trucks (i.e., the round headlight models) for the bezel. If you find one, make sure to get the lower part that goes under the column and keep in mind that the a/c bezel is different than the heater only bezel (a/c vent cutouts on the a/c bezels, no vent cutouts and a storage pocket on the heater truck bezel).  Lastly, keep an eye on ebay as instrument bezels do show up there from time to time at reasonable prices.
Post by: Captkaos on February 06, 2013, 07:34:11 am
The cluster housing is busted where someone decided to put aftermarket gauges in the lower left slot, if you plan to put a factory gauge in there, you are going to have issues as it appears there is no contact on for the factory gauge to get power.  The one to the right of it where someone put a tach "appears" to be ok.
The ears usually can be fixed if you have all the pieces by glueing it with expoxy for plastic.  It isn't a cosmetic piece so it just needs to hold.  With that said, with the hole in the lower left, I don't think you are going to be able to use this cluster, and you will need one which matches what you have and that is 1973-74 ONLY.
