73-87 Chevy _ GMC Trucks => Suburbans => Topic started by: piston383 on February 27, 2013, 11:38:00 pm
Hi everyone, I've got a small problem I was hoping I can find some help woth. I have an 88 suburban with a tikt column. The column was loose (typical tilt bolts backing out) so I was in the process of taking it apart when I broke off my pivot pin remover inside one of the pins (driver side). Is there a way to get the broken piece out without destroying the pin itself?
You broke the tool off in the pin? That is a tiny bolt, did you get it out or is the pin still in? I don't know of a ez out that small.
Did it break off flush? Recoil makes a small screw extractor kit that might work (4507P), but it costs about $50.
