73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Slamm3d_86_c10 on March 05, 2013, 08:57:14 pm
Title: 86 c10 with starter/ flex plate issues ...
Post by: Slamm3d_86_c10 on March 05, 2013, 08:57:14 pm
Anyone have any issues with their trucks starting up clean ? I'm at a loss with my truck I put a new starter in it, also had a tranny shop put a new flex plate in it and first couple of days it started up fine. a few days later it would grind once and awhile when I would start it then
Tonight when I got home it idled high then after I shut her down I turned the key off and the starter was just spinning anyone have the same issue? ???
Title: Re: 86 c10 with starter/ flex plate issues ...
Post by: bd on March 05, 2013, 09:20:37 pm
Starter was spinning with the key off?
Post by: Macj1983 on March 05, 2013, 09:43:27 pm
Sounds like a stuck relay something is telling it to come on
Post by: Fairlane514 on March 05, 2013, 09:52:46 pm
Did you check the clearance between the starter teeth and the flywheel teeth and shim it if needed?
Post by: Slamm3d_86_c10 on March 06, 2013, 05:12:24 am
Yes the tranny shop said that it lined up very nice and didn't need any shims ... Idk this morning gonna pull the flex plate cover off and take a peek at it ,almost sounds like it ripped the spur gear right off the starter.
Post by: stereojnky on April 08, 2013, 12:44:12 pm
Did you ever figure out what the problem was? I'm having the same problem. I've tried new starter, flexplate, & bolts. Shimmed up, starts good for a few times, then horrible grinding noise. I'm thinking a hairline crack in the mounting boss.
Post by: Irish_Alley on April 08, 2013, 09:54:41 pm
are the bolts working loose
Post by: bobcooter on April 08, 2013, 10:14:22 pm
That sou
That sort of sounds like a cracked flex plate.
