73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: dirtracer55 on March 27, 2013, 07:50:00 am
Title: big block install
Post by: dirtracer55 on March 27, 2013, 07:50:00 am
I am in the middle of a swap from a small b lock to a BBC in my c-10, the only problem that I'm seeing is the power brake booster being in the way for any valve train adjustments with out removing the entire booster. Any thoughts would be helpful.
Title: Re: big block install
Post by: Engineer on March 27, 2013, 10:10:19 am
I never had that problem. It is tight, a pain to get the valve cover off, but it is doable.
Post by: dirtracer55 on March 27, 2013, 10:39:00 am
even with tall valve covers? Have a roller cam and stud girdles so its a pain but it can be done?
Post by: Engineer on March 28, 2013, 08:35:01 pm
I have tall valve covers, and roller rockers, but no stud girdle.
The stud girdle may be the game changer.
Post by: Nthefamily on November 01, 2013, 10:08:10 am
I have the same issue with my '85 k10.
Engineer, what valve covers did you use? I do not have girdles.
The slanted cast aluminum from Summit will fit, but do not have baffles.
Post by: Engineer on November 02, 2013, 09:29:47 am
I have some plain tall chrome stamped steel valve covers that I bought from Jegs.
They are the cheapest valve covers in the catalog, but are made from pretty heavy steel. Probably 18ga or heavier. They do have baffles. After a while they rusted, so I sandblasted the chrome off, and repainted them with the hammered finish Rust Oleum paint in silver. They look pretty good.
Never had aluminum covers on this engine so I don't know how they will fit.
Post by: Nthefamily on November 02, 2013, 06:20:08 pm
Bought a set of GM Performance cast aluminum valve covers (part # 25534374) today from Summit and they fit great. Have holes for breathers and had baffles, unlike what the website says. Now time to finish putting his hoss back together and see if she'll crank.
