73-87 Chevy _ GMC Trucks => Fuel Systems and Drivability => Topic started by: agilbert81 on March 29, 2013, 08:42:57 am
Title: After Market Fuel Neck Housing
Post by: agilbert81 on March 29, 2013, 08:42:57 am
Hi all,
Does anyone know a good source to get an after market Fuel neck fill housing.
Title: Re: After Market Fuel Neck Housing
Post by: zieg85 on March 29, 2013, 08:59:47 am
Not off hand, what are you trying to do?
Post by: hoyle83 on March 29, 2013, 10:48:58 am
i'm with ya on this one...i need ine bad and everything at the wreckers is rust city! Piece of fuel hose big enough to replace mine with the 90 degree at the bottom is 40 bucks to boot!
Post by: bake74 on March 31, 2013, 08:14:39 pm
     This is one of the times in everyone's life where a decision needs to be made.  Is money more important or your time.  I have spent days looking for a part like a filler tube that would work, only to end up spending the $40.00 because in the end that is what was available.
Post by: hoyle83 on April 02, 2013, 12:38:57 pm
Lol a slow moving project sometimes doesnt need a quick decision made in my case anyways(cant get the steel filler at all, and was only referring to the rubber hose price because that's all i had found!)...just putting it out looking for assitance is all Bake.
Post by: agilbert81 on April 02, 2013, 07:25:47 pm
Here's what I'm trying to do. I have a 74 Chevy k10 short bed with dual tanks. I just got a bed off of an 80 Chevy. But someone patched in the hole for the driver side fuel fill neck. So I'm needing to to find an aftermarket fuel fill neck housing and cut a hole in the bed panel for it. But I'm not having much luck finding them.
Post by: bake74 on April 02, 2013, 08:58:14 pm
     I do remember someone posting about getting a filler neck off a diesel truck that works real good because it is oversized.
Post by: Cedens on May 26, 2013, 10:30:22 pm
Wow interesting, my 82 has the Drivers Side Filler neck all messed up, it seems DOD (dear ol' dad) modified it to run leaded fuel back in the day, not a huge problem it still holds fuel and fills it's just a pain at the pump
Post by: blazing816 on May 28, 2013, 08:31:19 am
I doubt someone patched in the hole, the trucks that did not have dual tanks, only had one filler door on the bed, and I am pretty sure the door was always on the passenger side when there is only one tank. I would say it will prob be easy just to find a bed with two door, once you find one that works weld it all in and make sure the filler neck fits to it, be easier just to get one with dual doors. Just my $.02
Post by: 74 C-10 Shorty on May 28, 2013, 09:14:08 am
I agree, way easier to get a dual door bed..
