73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: realdiehl on April 01, 2013, 09:18:30 pm
Title: Rear end swap questions
Post by: realdiehl on April 01, 2013, 09:18:30 pm
I'm getting ready to install my flip kit and notch as well as swap my rear end.  My truck is an '84 C10 SWB with a factory rear end.  I'll be swapping in an earlier 12 bolt, (was told it was a '76 or '77).  I already rebuilt the rear end/put a unit in it.  I believe I'll have to switch U-joints, can anyone confirm this?  Is there an adapter u-joint PN?  Also, will all the factory brake pieces from my 84 rear end bolt on to this earlier one.
Post by: Tx Firefighter on April 02, 2013, 09:46:44 am
This is the conversion u joint to adapt your driveshaft to the 12 bolt rear end yoke. You can get them at the parts store for under 15 dollars
(http://i276.photobucket.com/albums/kk33/Adventure-rider/78%20half%20ton%20project/97DBEC9E-2482-412A-B2B6-3334FC93EB13-17845-00000DCAC4290B3B.jpg)
Title: Re: Rear end swap questions
Post by: 86c10 on April 02, 2013, 10:01:24 pm
I've looked into the same swap on my '86 c10. The 10 bolts came with either 2'' or 2 11/16'' shoes, so you'll have to measure what is on you 10 bolt and compare it to your 12 bolt. From what I could tell just looking on oreilly's website the wheel cylinders are different and I'm not sure about the e-brake cables.
Post by: choptop on April 03, 2013, 07:19:47 pm
Ebrake cables are the same. If the 10 bolt is the 2-11/16. and the 12 bolt is the two inch, you can change the 12 bolt to the 2-11/16. You will have to pull the axles and replace the back plates and all hardware. I did this last year on my red truck. I changed to the 2-11/16 because I had all new drums, brakes and hardware for the 2-11/16 brakes.
Post by: Blazin on April 03, 2013, 11:16:37 pm
I have swapped 84 baking plates off a 10 onto a mid 70s 12 bolt before.
I swapped a 5 lug 12 bolt into my 84 K10. Swapped in some 6 lug 12 bolt axles after the backing plate swap. Popped the conversion joint in, and I was back on the road.
Post by: realdiehl on April 07, 2013, 07:35:44 pm
This is the route I'm going.  I've left the axles loose on the 12 bolt, so after I put my notch in, I'll swap the brakes and put the rear end in at the same time.
Thanks everyone, and thanks for the Napa PN.   :D
