		73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: flips87c30 on April 12, 2013, 08:35:15 pm
				My truck has recently developed a cough/stutter it only seems to happen at mid throttle it wont happen once I am up to speed, or when I give it more to get up a hill. But going from a dead stop it coughs like crazy. It also runs just fine in park I can rev it up no problems. Im thinking I should start looking at the distributor cap and rotor. I just replaced them mabey I screwed something up? Any suggestions? Thanks in advance.
				I'm almost sure that you have a vacuum leak.  Probably a cracked rubber line somewhere.
				Been working on the truck all morning still cant figure this out. I cant find any leaking vacuum lines. It runs fine for a mile or two then starts acting up again.It was running fine, before I replaced the following, right side exhuast manifold, dist cap and rotor, map sensor, thermostat, and the preheater hose. this cough has me stumped its almost like a really quiet backfire. Could it be my pick up coil? At this point im just guessing.
				Could you have accidentally crack the ceramic on a spark plug or damage a spark plug wire?
				yes. thanks zieg. I dont even know what to say for myself.
				Try Robitussin  ;D
 So is it skipping or hesitating?
				My initial thought was "does anyone have a Ricola?"
				RRRRIIIICOLAAA!!!!
				Try Robitussin  ;D
 Obviously tried Robitussin first thing but it fouled my injectors, the vicks vapor rub on the air filter proved equally useless.  In all seriousness I guess Its skipping. But I think I found my problem when I looked closely at the plug wires. one was partially melted. time for a new set. any suggestions, What brand do you guys use?
				I run off the shelf stuff for my driver..  Accel MSD or Taylor for my non-stock stuff.
				Always run a good quality set of ignition cables don't get the cheap ones.
