Does anyone know where I can get all the bolts and hardware I need to attach the front and rear axles.
Thanks
can you elaborate a little more......what bolts/hardware do you need?
Toys are my game
Well I have a bare frame with only the brackets that are riveted on to it. I need the shock mounting bolts,front sway bar bolts, and I need all the bolts that connect the springs to the hangers and shackle assemblies. I also need the bolts that mount the cab, box, radiator, and the rest of the drive train, but I'm not to the point of putting the body and drive train on yet. I hope this helps.
Truck catalog has all of the bolts, fasteners, bushings and parts you'll need for this. www. competitor.com. Good Luck!Mike and Crystal
Any local Bolt store should have the bolts/nuts you need.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
I'm gonna go with and some of Lawson's hardened steel grade 8 bolts for the hardware. Thanks
