73-87 Chevy _ GMC Trucks => Interior & Equipment => Heating, Ventilation & Air Conditioning (HVAC) => Topic started by: cwilson jr on July 12, 2013, 09:19:12 am
Title: refrigerant capacity
Post by: cwilson jr on July 12, 2013, 09:19:12 am
how much ref. do our systems take?  i have an 85 k10 with the r4 compressor.  i remember seeing something around 3.25 lbs. and now i can't find it.
currently, it's cooling so so and reading on the very beginning/bottom of the "full" zone on the gauges, which without looking at the moment i believe is around 40 psi @ about 80* outside.  i only have 2lbs. 12 oz. in now, so i'm thinking i need to add more to get closer to around 3lbs, or whatever the correct full charge amount is?
also, what temp. range should i be getting out of my vents?
Title: Re: refrigerant capacity
Post by: zieg85 on July 12, 2013, 05:43:19 pm
You would have thought the Chilton's 1980-87 GM truck manual would have that info, sorry it doesn't.  It has everything else though...
Post by: cwilson jr on July 12, 2013, 06:56:09 pm
lol.  yeah really.  i have the chilton's and haynes and i don't see it in either.
Post by: rich weyand on July 12, 2013, 07:42:57 pm
1978 GM Light Truck Service Manual says 3 pounds.
Post by: Irish_Alley on July 12, 2013, 11:35:37 pm
did you add oil?
Post by: cwilson jr on July 13, 2013, 11:14:43 am
i added a small container when i had to replace the compressor.  i believe it was 6 or 7 oz.
Post by: werewolfx13 on July 13, 2013, 12:41:54 pm
You didn't specify which refrigerant..R12 and 134A call for different weighted volumes.
Post by: cwilson jr on July 14, 2013, 09:20:58 am
134a
Post by: bd on July 14, 2013, 12:52:36 pm
During 1985, R-12 refrigerant capacity was bumped to 3.5 lbs.  When substituting R-134a, adjust the charge weight to 3.2 lbs.
Post by: zieg85 on July 14, 2013, 02:44:32 pm
Thanks BD, I didn't know that and will eventually recharge the AC on my 85 which was converted some time back and has a leak.
Post by: cwilson jr on July 15, 2013, 10:13:40 pm
ok, and i imagine i add in the amount of comp. oil as part of the charge as well?, so, with:
2x 12oz. cans of high mileage 134a w/oil added
1x 12oz. can 134a
8oz. of compressor oil
i get 44oz. that i have already introduced and with the charge capacity of 3.2 lbs. = 50 oz., i'm thinking i'm pretty good? or adding a little more possibly.
Post by: bd on July 16, 2013, 01:25:08 am
Is this the same truck with the pulley alignment problem (http://forum.73-87chevytrucks.com/smforum/index.php?topic=26370.msg219760#msg219760)?  Did you replace the accumulator?  Did you evacuate it before attempting to recharge?  Did you replace any other parts?  The answers to these questions are significant.
134a systems are sensitive to oil charge as well as refrigerant charge - it's easy to flood a system with too much oil, whereas cooling performance suffers if the correct refrigerant charge isn't added.  So, how much oil have you actually added thus far?
The rule of thumb for oil charge in our trucks is 6 oz in the compressor, 2 oz in the accumulator, 1 oz in the condenser, and 1 oz in each evaporator on a brand new, or otherwise empty, system.  That's a total of 10 oz of oil for a 2-door cab.  The problem you're facing is not knowing exactly how much oil is distributed between the various components, now.  Notwithstanding, you can make a reasonable estimate.
If you replace the compressor again, drain the oil out of the existing compressor into a measuring cup.  How much oil did you recover?  Your net charge should be 3.2 lbs (~51 oz) of R134a (or about 4.25 12-oz cans), plus 10 oz of refrigerant oil (6 oz poured directly into the compressor suction port, the balance poured directly into the accumulator).
The coolest air you can expect from a factory system depends on the ambient temperature and humidity, but don't expect much cooler than about 50° F.
I hope this has helped.
Post by: cwilson jr on July 16, 2013, 07:49:29 am
this is exactly what i have done so far in the order which i completed it as well:
flushed - evaporator, lineset and condensor
replaced - accumulator w/ new switch and compressor
evacuated system
then started to introduce ref. and noticed my comp. was locked once the cycling switch engaged.
removed and replaced the compressor and added oil - the entire 8 oz. can of compressor oil and used it to pour into both ports, before i knew better.
added 1x can of regular 134a
NOW, i am waiting on that new compressor to arrive and i'm going to have my local guy recover my charge and take your advice on the new compressor oil.
Post by: bd on July 16, 2013, 09:44:20 am
That's good news!  Since you flushed the system and added exactly 8 oz of oil, you know exactly how much oil is in the system.  Recover the oil from the existing compressor when you swap it out, and add that same amount to the new compressor, plus 2 oz, for a total of 10 oz. There is a light at the end of this tunnel!
