73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: oscars84 on July 18, 2013, 11:08:22 pm
Title: need help with engine accessories
Post by: oscars84 on July 18, 2013, 11:08:22 pm
I just bought a 350 and it has no accessories or brackets on the front of it. The year of the motor is a 85. How or where do i start looking to get these parts and brackets? Will later year brackets and accessories fit on an older motor?
Title: Re: need help with engine accessories
Post by: Irish_Alley on July 18, 2013, 11:25:00 pm
do you have the holes for them in the heads? since you have to replace them anyway you might want to think about converting over to serpentine system
http://www.carcraft.com/techarticles/ccrp_0911_serpentine_belt_drive/viewall.html
Post by: oscars84 on July 19, 2013, 12:28:17 am
Yes that is exactly what I want to do a one belt system. What do you mean do I have the holes in the heads for them?
Post by: Irish_Alley on July 19, 2013, 01:18:38 am
double hump head are sometimes swapped in place of stock heads for more power. the double hump heads have no accessory bolt holes for brackets. was thinking is this why you dont have accessory or was there another reason.
Post by: oscars84 on July 19, 2013, 06:57:06 am
The motor had all the stuff on it before I bought it. It was a 3 belt system but the guy said he was keeping it all.
Post by: winky on July 19, 2013, 09:02:16 pm
I'll m a pic of the engine I put serpentine setup on tomorrow. Best thing is to buy an early 90s throttle body engine that has been locked up etc for like $200 and just set it near you truck and swap everything
Post by: oscars84 on July 19, 2013, 09:12:52 pm
Thanks that would be helpful. I guess that's what I was trying to ask. So a newer 350 motor accessories will fit my 85 350?
Post by: oscars84 on July 19, 2013, 09:38:46 pm
@winky is your heads like what irish alley is talking about?
Post by: Captkaos on July 20, 2013, 12:08:07 am
Just find a donor serpentine system and bolt it up.
Post by: oscars84 on July 26, 2013, 10:55:52 pm
Ok I'm going to make this simple. Will a serpentine system off a early 90'sbolt right up to my 85 350?
Post by: winky on July 27, 2013, 08:08:59 am
Most likely yes. I'm about to go out and send you one pics
Post by: winky on July 27, 2013, 10:36:31 am
84 engine and 90 model with serpentine. You probably don't have hole 6 (blue one on the 84 pic) sorry the pic is blurry. You could make a bracket to connect the back of the ac to the intake or drill and tsp a hole for that spot. Also if you go serpentine you'll need a 90 model water pump and cooling fan (the belt routing spins them the opposite way)
(http://i1269.photobucket.com/albums/jj582/josh_brooks2/engine.jpg)
Post by: winky on July 27, 2013, 10:40:11 am
(http://i1269.photobucket.com/albums/jj582/josh_brooks2/901.jpg)
(http://i1269.photobucket.com/albums/jj582/josh_brooks2/902.jpg)
