73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: jonny on August 07, 2013, 08:39:28 pm
Title: transfer case problem
Post by: jonny on August 07, 2013, 08:39:28 pm
My 87 jumps out of four wheel frequently when mudding. Sometimes its easier to just prop my foot on it to hold it in four wheel drive. Everything else working great. Any ideas what needs attention?
Title: Re: transfer case problem
Post by: bake74 on August 07, 2013, 10:45:51 pm
     Check the adjustment for the shift linkages.  At the same time check on the mount bushings.
Post by: Powerdriver1958 on August 09, 2013, 09:05:35 pm
Use your favorite spray lube on the pins and linkage . Hose out the shifter and lube the daylights out of it . Mudding has its own problems . mud may get in the shifter , When mud dries it will draw any lubrication out .
Post by: Engineer on August 09, 2013, 09:51:01 pm
NP208?
4x4 Lo?
4x4 Hi?
I'm guessing a bad bearing in the planetary.
Post by: Powerdriver1958 on August 10, 2013, 12:00:50 am
Forgot to ask , Body lifted ?
Post by: Irish_Alley on August 10, 2013, 12:10:48 am
know he got a 205 but i dont think he put it in yet
Post by: jonny on August 13, 2013, 06:09:14 pm
6"lift but stock 400trans
Post by: Powerdriver1958 on August 13, 2013, 06:32:09 pm
One thing to look at . Some times if your wheeling hard enough you can get lot of flex and the transfer shifter will be bumped out of gear with the floor pan . Mine I had to open the hole up and use a big hurst shifter boot .
(http://i1310.photobucket.com/albums/s653/furdbarful/a20c4b0e-53c9-43c1-8454-c4fa82dbc1b6_zps0ce04cc6.jpg)
Post by: Irish_Alley on August 13, 2013, 10:46:50 pm
like power said i seen them be touching the front of the floor pan, enough to engage but any shift in the trans/cab will cause it to pop out
Post by: jonny on August 14, 2013, 09:55:35 am
That's a real possibility, most people don't even like riding with me offroad. They say I drive too fast. I'll be cutting hole out before hunting season. Thanks
Post by: Irish_Alley on August 14, 2013, 11:47:05 pm
just take the boot/cover off and see if its close. take her for a test drive and see what you can see
