73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: Big Daddy on August 23, 2013, 07:56:46 pm
Title: np205 question
Post by: Big Daddy on August 23, 2013, 07:56:46 pm
Will an input shaft from a 350 turbo/205 transfer case (1980 slip yoke 205) fit into a 205 that has the 10 spline input shaft?  I would prefer to swap the parts that I have before I go out and buy an adapter I might not need
Title: Re: np205 question
Post by: Irish_Alley on August 24, 2013, 12:09:55 am
cant say for sure about the input shaft, but i know you can swap output shafts. so i would assume its the same, since the 10 spline and 27 spline use the same input shaft bearing
Post by: Engineer on August 28, 2013, 08:36:35 pm
Yes you should be alright.
The 205s from a Turbo 400 had a larger input bearing, but the 205 case housing for the TH350, and SM465 applications were identical.
