73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Jeff86inMS on September 23, 2013, 10:53:08 am
Title: 305 Issues, need your help
Post by: Jeff86inMS on September 23, 2013, 10:53:08 am
Hey Guys!  Looking for some advice.  I have a 1986 Custom Deluxe C-10, 305 CID stock motor.  I've had the truck about a year, and it has started acting up, so I have started replacing things.  Started with a tune up, since I had no idea when the previous owner did it last, wires, plugs, cap, rotor, all new filters (fuel, oil, air), changed the oil.  I thought the tune up would fix my issues, but it's getting worse.  When I crank it the engine runs and cranks fine, but when I get it out on the road and try to accelerate, it doesn't.  It seems to just want to "squat", if that makes sense.  I have had the carb adjusted a couple of times prior to the tune up, when my choke thermostat went bad.  Would the carb need to be readjusted with the new tune up components installed?  The carb is pretty nasty and have thought about replacing that too, so my next question is what should I go with, any reccommendations?  Any suggestions on how to fix my problem would be greatly appreciated.  I don't want to get in the cycle of just throwing new stuff on it in hoes on the next "new" part fixes the problem.  That gets costly.  If it was the fuel pump, would it even start?  This is my daily driver, so I need to get this baby back on the road.  Thanks for any diagnosis/advice you can offer.  Yesterday afternoon I tried replacing the fuel filter, got it back on the road, same issue.  I can actually press the pedal all the way to the floor and it barely wants to accelerate.   HELP!!!!
Thanks again,
Jeff
Title: Re: 305 Issues, need your help
Post by: rich weyand on September 23, 2013, 11:00:41 am
What's the timing set at?
Post by: Jeff86inMS on September 23, 2013, 12:38:37 pm
Rich - I'm not sure.  I'm afraid I'm not the mechanic I would like to be, gaining experience everyday.  I'm not sure what the timing is.  I haven't changed any of that from what it was before prior to installing all of the tune up components.  Would the timing typically have to be reset after those components are installed?  I'm embarrassed to be so ignorant on these matters, but my limited knowledge is what it is.  I guess I'll nurse it down to the shop to see if that's what needs to be done.  I can probably borrow or rent a timing light but would have to learn how to use it.  Thanks for the input, that gives me something to check into.
Post by: nlauffer on September 23, 2013, 01:08:14 pm
Something quick and easy you can check with out tools.  Grab ahold of the distributor, preferably right below the cap, and try to turn it.  If it moves, the timing could be off.  You can also look at the distributor where it enters the engine through the intake.  There should be a bolt and hold down tab.
Another option is check all the spark plug wires.  If you replaced these and it is getting worse, it could be that a couple are out of sequence.
These are easy and require no tools to check.  The farther you go, you may need to take it to a shop or someone that is knowledgeable.  This could be many things, timing is a very good possibility.  Maybe related to engine internals, though. Like a broken valve spring or any number of other.
How about the vacuum line running to the distributor.  Did it come lose or is it leaking?
Post by: Jeff86inMS on September 23, 2013, 02:11:38 pm
Good suggestions.  I'll check those things as well.  I did check the wires with the Haynes manual twice to be sure I did not have them crossed.  I'll check the distributor to be sure it's not loose and check the vacuum line as well.  One thing I will say I noticed.....all of the vacuum lines need to be changed/replaced.  They are all in terrible shape.  Noticed that when I had the air cleaner housing off.  At least all the rubber needs changing, there are some hard plastic lines as well, though they appear okay.  I'll check those things and post the results when I get home.
Post by: thirsty on September 23, 2013, 02:34:02 pm
vacuum advance maybe?
Post by: bd on September 23, 2013, 08:45:55 pm
Does it 'squat' when the engine is cold as well as warm?
Post the results.
Post by: Jeff86inMS on September 24, 2013, 06:56:46 am
nlauffer - I checked the distributor, not loose as suspected.  Also rechecked wires, seems they are good as far as being on the right plug.  Checked vacuum line to distro, still attached, can't really get a good view of the condition but as I said, all the vacuum lines are trash, probable need to go ahead and replace all of them one by one as "BD" suggested.
BD - Great suggestions.  Though I'm not in a $ position to go buy a lot of tools, it seems that I need to start picking up some of these things and learning how to use them.  I'm sure I could save myself a lot of money in the long run by being able to diagnose these things myself.  I'll search these items out and report back.  As I posted before, all of the vacuum lines are trashed, based on the condition of most, I cannot imagine them not being the original hoses and look very well deteriorated.  I'm changing those as we speak.  Thanks again guys, super appreciative!
Post by: nlauffer on September 24, 2013, 09:22:45 am
What parts stores are in your area?  Some I have heard rent tools.  You have to put a deposit down, but get it back when you return it clean and unharmed. This might allow you to do some of the checks without spending much money.
Post by: Irish_Alley on September 24, 2013, 11:31:52 pm
the rental tools come with a warranty so you can break them if you want lol. but what carb do you have?
Post by: Jeff86inMS on September 25, 2013, 06:53:36 am
Irish_Alley - I think it's the original Q-Jet, but have not really researched it.  I have had to have it adjusted a couple of times and it has been suggested in the past that I replace it with something along the lines of an Edelbrock or Holley.
I did make it to the shop yesterday,  Local garage I have used in the past is about 4 miles down the road.  I have some hills between the house and the local garage that gave me some concern, didn't know if the truck would even have enough power to make it up the hills in it's current condition.  It took me about 2 miles just to get up to 45 mph, but up made it to the shop.  Hopefully they will know something today.  I'll post any results.
Post by: Boone83K10 on September 25, 2013, 07:27:16 am
sounds like a clogged exhaust system, specifically the catalytic converter. Cars start and run fine but have absolutely no power when you try to accelerate. This is all premised on you still having the cats...
if not, I would look towards the carb. I could range from just a clogged fuel inlet filter all the way to you just need a new one. replace the vacuum lines, it's cheap and gets away from trying to chase down a vacuum leak which is so annoying.
Post by: Jeff86inMS on September 25, 2013, 08:02:22 am
Thanks Boone!  Yes, I still have the converter on the exhaust system.  Would the converter make any noise if it was clogged (rattle or something)?  Haven't heard anything.  As I said previously, the vacuum lines are trash and I agree with you, they all need to be changed out.  What about the "shaped" rigid plastic lines?  Are they available in a catalog somewhere?  Have had a couple of those break at the rubber fittings and had enough slack to reconnect them.  Do they make a "Vacuum Line kit" for a 305 that has all the sizes/lengths or do you just buy them separately?  I'll check around.
I changed all of the filters including the fuel filter at the carb inlet as well.
Post by: greasemonkey54 on September 25, 2013, 12:08:09 pm
I would check the ESC module. You unplug the connector from the dist. and jump 2 wires together but I cant remember the colors off hand. I would need to look. If it runs better you permanently run those wires together or replace the dist with an older style HEI
Post by: 454Man on September 25, 2013, 12:43:50 pm
   black and green
What's under the hood??? If you have to ask maybe we shouldn't race...
Post by: Irish_Alley on September 26, 2013, 12:32:52 am
there aint nothing wrong with the Quad. if you want to replace it you can buy a new one or just rebuild your old one for under $30. the cat wont make any noises, will get hot, might glow, might smell like rotten eggs, top speed might be limited and loss of power. one way to test them is take out the O2 sensor before the cat or open the pipe up before the cat somehow or even just cutting it, if it runs better the cat is your problem if not you should look at fuel. just want to make sure but you did replace the fuel filter in the carb inlet right? there might be more than one also
Post by: Jeff86inMS on September 27, 2013, 07:56:41 am
OK, here's the deal.  Not sure if witch craft is involved, or the earth has adjusted its axis, or planets that never align have aligned.....but I got it to the local shop Tuesday evening, waited to call them until yesterday noon.  They said they "can't find anything wrong with it, drives fine".  WTH???  I am dumbfounded!  I even drove my wife around in it to prove what I was saying so she wouldn't think I was crazy.  When I drove up to the shop on Tuesday, it took me 2 miles to get up to 45 mph.  When I picked it up yesterday, they were right, it drove better than it ever has since I've owned it.  Only thing I can figure is that there was some sort of trash in the fuel line that broke loose, I don't have a clue, but I'm not gonna look a gift horse in the mouth.  If it does it again, I'll take it back of course.  That being said, there is nothing to report as far as a fix.  I almost wish they would have found something to fix.  At least that way I wouldn't have to wonder.  BTW, no charge at the shop.
Guy's I truly appreciate the advice and responces from you fine folks!  Proves America still has the greatest folks in the world, that take time to "help their fellow man".
Regards,
Jeff
Post by: greasemonkey54 on September 27, 2013, 11:07:17 am
when my ESC went bad it would act up whenever it wanted to. Good luck and hope she stays good for you
Post by: Fairlane514 on September 27, 2013, 09:25:45 pm
Makes sure your advance weights in the distributor aren't stuck.  Sounds like the motor won't rev.
Post by: Jeff86inMS on September 30, 2013, 06:34:31 am
I'll check the weights to make sure everything is moving freely.  Thanks Fairlane514!
Post by: Boone83K10 on September 30, 2013, 07:49:23 am
It would not rattle...
Not sure about the hard lines, but I assume using rubber replacement won't hurt them....I mean I would replace them without thinking about it.
Post by: Jeff86inMS on October 03, 2013, 01:15:11 pm
Can anyone tell me what the sensor threaded into the rear of the intake manifold is on my 305 is?  I have an "H" code VIN number.  It almost looks like an Oxygen sensor, but thought that would be down on the exhaust.  I noticed it the other day during my tinkering.  It's on top of the intake, screwed directly into the intake right behind the carburetor.  It has a wire coming out of the top. Any clue??
Post by: Boone83K10 on October 03, 2013, 03:38:49 pm
most ports directly behind the carb are for manifold vacuum.
so maybe a MAP (manifold absolute pressure) sensor?
Post by: bd on October 03, 2013, 07:31:13 pm
That's an odd location for a truck engine sensor.  Can you post a pic?
Post by: Irish_Alley on October 03, 2013, 10:44:03 pm
the only sensor i can think of behind the carb is the oil pressure switch and it does have one wire if you have a gauge
(http://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/PS140/image/3/)
(http://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/PS117/image/3/)
Post by: Jeff86inMS on October 04, 2013, 06:35:01 am
Sure, I'll take a pic this afternoon if it's not raining too hard, got this tropical storm Karen coming my way, so it may be raining this afternoon, not sure.  I'll do my best.  The reason why I ask is that when I was doing my tune up recently, the sensor looked like it was threaded in crooked into the manifold, and was gonna fix it.  I thought it might be an O2 sensor.  When I started reading what an 2 sensor does, it sounded like a lot of what I was suffering from.  I looked up the part, not very expensive, so I thought I would just replace it.  I'll try to get a pic up today.
Post by: Fairlane514 on October 04, 2013, 07:30:56 am
If you have a stock carbureted 305 engine, you don't have an O2 sensor. I think its what Irish Alley posted......oil pressure sending unit.....they do look crooked.
O2 sensor is mounted near the exhaust manifold  (usually just below it) and would send information to a computer.
