		73-87 Chevy _ GMC Trucks => Electrical => Topic started by: james.gribbins.7 on November 10, 2013, 07:06:05 pm
				78 k10 350. All the lights work except the head lights, I used a volt meter an the bulbs them selfs are not getting power, I checked all glass tube fuses, all ok, changed the light pull switch, nothin. Ive read on here quite a bit what it could be but everyones story was a little off from mine, so any new thoughts on this will help.
 Ps I did take the truck off roading for the first time a day before going out, I dont have a splash plate so I did get some muddy water EVERYWHERE.
				Have you checked power at the floor dimmer switch?
 Have you switched between high and low beam while checking power?
				No, thats where I was going next, cuz I know those are only $10 bucks to replace if bad. But no I havent, ill try that after work an see what happens. Thanks for the reply.
 You're welcome and no problem on the reply.  Please report your findings, just in case someone else runs into the situation.
 You may also want introduce yourself on the new member page when you get a chance.
				Check the grounds.
				Ok, figured it out. It was silly. My dimmer switch on the floor was either dirty or loose, or even both. But unpkugged it, cleaned all the dirt off and pkugged it back in. bam! Lights. Thanks again. Will do.
